Donor Disco! - Defender Source
Old September 26th, 2016, 10:14 AM
jackstraw
geoff vezzetti
1998 d 110
Donor Disco!
I am getting ready to make some improvements to my 1988 defender ROW 110 5 door.
Disc brakes and new wheels.
this is an expensive proposition .
I was wanting to know what parts from a series 1 disco could be easily used on my Defender.
It would appear axels and wheels .. what else? seats? engine? ect.
I van get high milage series 1 for a few thousand bucks. I can't even get a decent set of wheels for that price.
thoughts,concerns?
thanks fellas!
Old September 26th, 2016, 10:21 AM
phoenix37's Avatar
phoenix37
john
Few thousand bucks for a donor D1? More like 600 bucks. What kind of wheels do you want for your defender that cost $3000 and come on a D1?!
Old September 26th, 2016, 10:27 AM
jackstraw
geoff vezzetti
1998 d 110
Black alloy 5 spoke. axels with disc brakes theres 6k worth of stuff right there!
Old September 26th, 2016, 10:46 AM
phoenix37's Avatar
phoenix37
john
seriously?! in what world?
here you go...i just saved you $5500 bucks.. feel free to paypal me a commission
1998 Land Rover Discovery
Old September 26th, 2016, 12:18 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Originally Posted by phoenix37 View Post
seriously?! in what world? here you go...i just saved you $5500 bucks by switching to Defender Source 1998 Land Rover Discovery
Fixed it.
Black Rhino Lives Matter
Old September 26th, 2016, 12:23 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
That truck has the Coveted Boost on it as well. The wheels are worth more than $500
Old September 26th, 2016, 03:04 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
I've got a '96 D1 that runs and drives great. I'll drive it out to you for $2500. OME/Bilstein lift, alloys, 235/85/16 tires. :D
Seriously though, here's how much I've spent on my D1's.
1998 D1, bought in 2008 for $3000. Nice truck, 70,000 miles on it.
1996 D1, bought in 2010 for $400. Shitty engine, faded paint.
1996 D1, bought in 2014 for $700. This is the one mentioned above. Daily drive it.
1995 D1, bought in 2014 for $700. It ran and drove great before I tore it down to rebuild.
So basically $4800 for 4 D1's
Old September 26th, 2016, 03:56 PM
jackstraw
geoff vezzetti
1998 d 110
We have drifted from my question a bit
Perhaps I am not using the proper lingo here.
Will the "rear end" meaning axel,diff,discs … the entire piece.
Can this be easily fitted to my 110?
Really just looking for an more cost effective way to add disc brakes to the 110 in the rear.
rovers north wants about 3000 for a conversion kit.
As I was looking….. it looks to be approx the same width. The trailing arms are in the same spot. the Prop shaft? looks to be 4 bolt as well..
Suggestions, comments death threats?
Old September 26th, 2016, 04:08 PM
phoenix37's Avatar
phoenix37
john
you should buy that truck..as was said the wheels alone are worth it.. anyway you should have a much beefier salisbury rear axle in your 110 than the one found on a D1. What are your plans for the vehicle? If its a mall crawler you should be fine with disco axles. If you plan to run bigger tire and offroad the truck than keep the rear axle you have.
Old September 26th, 2016, 04:16 PM
jackstraw
geoff vezzetti
1998 d 110
Yes thank you ..
I do not plan on rock crawling. Just some off roading mountain pass stuff and going up to the hills fishing. that sort of thing
Yes it has the diff of which you speak.
I had a 95 D1 and it suited my needs just fine. so I am guessing switching to a D1 would be fine.
It is just a matter of how difficult it would be to swap these out. Welding? ect...
Old September 26th, 2016, 04:58 PM
rovertrader's Avatar
rovertrader
Dale
A D-I axle with HD shafts is stronger than the Sals- and much better clearance! The A-arm fits fine, but the pinion on the Disco axle is 3 bolt with a rotoflex. You will need your rear shaft lengthened (any driveline shop can do) anyway, and just change the pinion to 4 bolt to afix the 110 rear shaft. Also, you will need the spring perches off the Sals to fit the larger 110 rear springs.
While you are scavenging from the Disco, grab the PS box if you ever want to convert to LHD. The front axle on the ROW is pretty stout even being 10 spline- much heaver duty CVs, but keep the D-I should you ever want to convert to LHD. Also, grab the T-case as it is a 1.2 which is a good highway gear/case.
The list goes on and on- good cheap way to get a good many parts!
disco
Gems disco donor Uncle Douglas Wanted 8 February 4th, 2015 09:21 AM
NAS 1995 Defender 90 for sale, Salvage title, Fully functional or Great Project donor Doc Martin For Sale - Vehicles 18 May 14th, 2012 05:58 PM
Donor 97 D1 swap to 94 D90... Kneel Defender Technical Discussions 2 September 9th, 2010 02:07 PM
Engine donor vehicles tkavan01 Defender Technical Discussions 20 February 12th, 2009 01:17 PM
Best donor 90 to do a diesel conv.? AggieD90 Defender Technical Discussions 11 October 30th, 2005 11:42 AM
