Dome Light Stopped Working When Doors Opened (D90 NAS ST) - Defender Source
Old January 25th, 2015, 12:02 AM
Nashville's Avatar
Nashville
Victor Hess
1997 Defender 90 NAS
I've had my D90 a little over a year and the dome light has always come on intermittently with either the right or left door being opened. When it works, after the doors are closed the light fades out via a timed controller.
A few weeks ago it simply stopped working altogether. I replaced the dome light and both door switches with new parts to no avail. I fear the gremlin may live in the control module stored in the upper dash above the center facia.....
I have the black wire going into the side of the dome light and the purple wires at the two end connectors. The forward switch successfully turns on the light, but when switched to the door open setting I get nothing.
Any experience is greatly appreciated.
1997 D90 ST NAS #1426
British Racing Green
Old January 25th, 2015, 02:49 AM
Fred Lobster's Avatar
Fred Lobster
Pete Gerbine, III
1993 110 (#451)
Might check the switches/buttons in each door jam. Remove the screws and clean them up...remove any surface rust on the screws and the holes they go in. I believe they act as a ground. That's what I did to get mine working properly....hope this helps....
Old January 25th, 2015, 09:23 AM
87 D110 (Ruby)
Originally Posted by fred lobster View Post
might check the switches/buttons in each door jam. Remove the screws and clean them up...remove any surface rust on the screws and the holes they go in. I believe they act as a ground. That's what i did to get mine working properly....hope this helps....
this
Old January 25th, 2015, 09:31 AM
yep- most likely the ground where the switch screws to the door jamb.
Old January 25th, 2015, 08:05 PM
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
I had this happen in my NAS 90 as well on the drivers door. I just replaced the door switch. Can find new ones pretty easy and they are a cheap fix.
90, d90, dome light, door, ht, nas, top
Front blinkers stopped working meow Defender Technical Discussions 8 September 16th, 2013 08:22 AM
Headlights stopped working JTull Defender Technical Discussions 17 November 29th, 2012 06:26 PM
AC stopped working. TxEddie1111 Defender Technical Discussions 5 September 23rd, 2010 03:27 PM
Indicators stopped working ... leastonce Defender Technical Discussions 1 November 2nd, 2009 10:25 AM
wipers stopped working MontanaD90 Defender Technical Discussions 1 February 25th, 2008 01:27 PM
