Dome Light / '97 Multi Function Unit - Defender Source
Old March 5th, 2007, 08:25 PM
GYM's Avatar
GYM
Gary
97 SW
Question Dome Light / '97 Multi Function Unit
I have an outwardly simple electrical gremlin that is evading me...
Dome light won't go OFF, except intermittently. Sometimes it starts to dim, but just before it goes out completely it pops back on.
So far I have replaced both door jamb switches (soft top), and the AMR5919 multi-function unit, (dimmer) to no avail.
I've eliminated the dome light assembly switch as a problem, (by swapping the ground wires on the toggle switch itself so that the manual On/Off side is now the auto dimmer side and vice versa the same issue occurs - on the other side of the switch).
I'm wondering now if it's a ground problem between the dimmer and dome light switch itself. (This function isn't somehow programmed through the ECU is it?).
Has anyone ever experienced this before? Any ideas?
(the only search reference I could find centered around the light not going ON...)
Thanks...
Garth
Old March 6th, 2007, 01:07 PM
pendy's Avatar
pendy
jim pendleton
89'd90
What about disconnecting ground at the MFU to check for a short to ground inline.
JP
legend in my own mind
Old March 6th, 2007, 05:53 PM
GYM's Avatar
GYM
Gary
97 SW
Good idea; I'll try it. Thank you, Pendy.
97, dome light, ht
Can I use a Dome light switch for hella lights tebby Defender Technical Discussions 4 September 5th, 2009 11:12 AM
Weird brake light issue on my 97 Please HELP! Cyborg Defender Technical Discussions 8 July 12th, 2009 01:04 PM
Need Oil light sending unit, 97 90 or Disco Tom Fitzgerald Wanted 2 April 14th, 2007 10:57 AM
Need 97 auto trans shifter light unit thingy wicks Wanted 2 December 22nd, 2004 12:59 PM
Rear Dome Light Stays On thug1313 Defender Technical Discussions 5 November 1st, 2004 08:33 AM
