Does your diesel have a favorite food? - Page 2 - Defender Source
Old December 3rd, 2014, 10:41 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by LuisC View Post
Uh, yeah! I'm beginning to have some regret to using the HS2.8. Though a good engine, it is finicky about what it drinks. I tried to build a vehicle that could hopefully use veggie oil. I found out the hard way it doesn't even like biodiesel in concentrations greater than 20%.
Yeah, it's one of those things where you might not put any thought to it. I would have figured diesel is diesel right?
One very small reason I went with the OM617 was I had read that it was veggie oil friendly. It is a long term plan to have it as an option. But I had no clue that certain diesel fuels could yield a difference in performance.
Old December 3rd, 2014, 10:46 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Ran out of diesel driving the Mercedes OM617 powered 110 on the highway on the way back to VA from Uwharrie and made it part way up an exit that had a 7-11 in sight with gas pumps, no diesel.
Bought 2 gallons of unleaded regular, poured it in, waited a few minutes for the 12V fuel pump to fill the empty fuel system up, stared the OM617 and drove 7 or 8 miles to the next exit where I filled up with diesel.
Didn't notice any difference running on gasoline except the temperature went up a little.
Cleaned 12 gallons of used crankcase oil with a centrifuge and didn't notice any difference.
Have run on hydraulic oil, ATF, and WVO and you also can't tell any difference.
Met a German engineer who was in the Wermarth many years ago while touring the Morgan plant in Malvern, Worcs, England.
He was chief engineer, but was a non-repatriated POW who told me that the allies were bombing the German refineries, oil fields, rail heads, and so on.
The Wermarth couldn't get fuel, so Mercedes designed fuel injection systems to run on whatever was available (apparently with his help).
Those multi-fuel injection systems continued to be built by Mercedes into the 1990s on production vehicles and dried up when the OM617 went out of production in about 2001.
RDavisinVA
Old December 4th, 2014, 07:46 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by rdavisinva View Post
Ran out of diesel driving the Mercedes OM617 powered 110 on the highway on the way back to VA from Uwharrie and made it part way up an exit that had a 7-11 in sight with gas pumps, no diesel. Bought 2 gallons of unleaded regular, poured it in, waited a few minutes for the 12V fuel pump to fill the empty fuel system up, stared the OM617 and drove 7 or 8 miles to the next exit where I filled up with diesel. Didn't notice any difference running on gasoline except the temperature went up a little. Cleaned 12 gallons of used crankcase oil with a centrifuge and didn't notice any difference. Have run on hydraulic oil, ATF, and WVO and you also can't tell any difference. Met a German engineer who was in the Wermarth many years ago while touring the Morgan plant in Malvern, Worcs, England. He was chief engineer, but was a non-repatriated POW who told me that the allies were bombing the German refineries, oil fields, rail heads, and so on. The Wermarth couldn't get fuel, so Mercedes designed fuel injection systems to run on whatever was available (apparently with his help). Those multi-fuel injection systems continued to be built by Mercedes into the 1990s on production vehicles and dried up when the OM617 went out of production in about 2001.
Robert, someone should build a freaking reality show around you man. Your experiences and your craft for telling them is priceless. You're a good guy.
Old December 4th, 2014, 08:31 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Only if Shayne or Jonsey played played the part...
Had a friend tell me that there should be a character on the Walking Dead who drives an OM617 powered Defender style Land Rover. On the show, this guy travels around helping the surviving humans and fuels up on fuel oil tanks next to abandoned houses that have an oil furnace and at grease disposal dumpsters behind restaurants.
Had a good laugh out of that one!
Did have a few people at work give me their used turkey fryer oil.
Burns nicely and the exhaust smells like a "barbie" with burgers on the flame.
RDavisinVA
Old December 4th, 2014, 10:34 AM
who ?
Old December 4th, 2014, 11:27 AM
87 D110 (Ruby)
Spending $20K plus on a 25 year old Land Rover,
Cranking wrenches, and spending more money on it,
Going to 4WD Events and spending time at a campfire with a bottle of port and Robert Davis...
PRICELESS
Old December 5th, 2014, 09:18 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
https://www.google.com/maps/d/viewer...8.kMNbgsUtH7OQ
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old December 5th, 2014, 09:23 PM
Originally Posted by ini88 View Post
Interestingly enough...the 45-cetane station near me is not on that map.
Old December 5th, 2014, 10:47 PM
ini88's Avatar
ini88
Daniel Marcello
I think we should start adding to it. The map owners email is in the side bar under the description. Id like to fine some more in the northeast. Maryland looks good though!
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old December 5th, 2014, 11:56 PM
PRICELESS
you need to come to Portsmouth in June.
Old December 6th, 2014, 02:12 PM
1of40's Avatar
1of40
1of40
I've been experiencing an unusual knocking in my 60k NA lately. First I thought it was valves out of tune. They turned out to be a little off the mark but not what I would consider way out of whack. So after reading this thread I decided what the hell, I've driven this NA about 4-5k miles since I brought her over a couple years ago without fuel additives or paying any attention to the grade of fuel I've been using. Long story short, I threw a quart of ATF in a full tank of shell diesel. WOW! magic! What a huge immediate difference. Sold. Thanks Guys!
Clay
Old December 6th, 2014, 02:21 PM
did you do the intake gasket and downpipe yet?
Clay
Old December 6th, 2014, 02:32 PM
1of40's Avatar
1of40
1of40
Negative. Spoke to The Rick Man and it sounds like he has the pipe though.
Old October 4th, 2017, 01:34 PM
Eugenemsmith
Eugenem smith
2015
Very informative thread.
Old October 4th, 2017, 01:57 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
New to this compression ignition thing....the Isuzu in the Perentie.
I've only put in ten gallons in the past three weeks...local pumps all seem to say "may be between 5% and 20% Biodiesel".
All I know is that it smelled like a tractor is supposed to before...and now smells like a campfire.
Old October 4th, 2017, 03:05 PM
roverguy2's Avatar
roverguy2
Brian Morton
1991 Defender 110 "Blanca"
Keith, I run B20 all spring and summer here in CO and my truck loves it. When I can't get it because I'm away from home or in the winter I notice the lack of smoothness in the engine. The smell is noticeable as well my wife doesn't like the Bio fuel smell during the summer.
Do you have a turbo or is it NA?
Old October 4th, 2017, 03:22 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Jonsey did, just a few years later, but in June.
RDavisinVA
Old October 4th, 2017, 03:24 PM
UnfrozenCaveman
Keith Armstrong
Various
Thanks Brian
It's n/a ... this year
I have this feeling that Iowa has plenty of biodiesel to go around.
...edit...
crap, I owe Mister Davis some pics of the rear seat belt bars in the 90!
Blast....I'll get them tonight!
diesel
What's your favorite.. Departing90 Misc. Chit-Chat 2 March 15th, 2009 10:16 AM
Earn Your Favorite Charity $100-$1000 pcarey Misc. Chit-Chat 0 November 1st, 2008 09:10 PM
What ‘Power Wheels’ type Vehicle does your son/daughter have? LRNAD90 Misc. Chit-Chat 9 July 17th, 2008 10:18 AM
What's your best/favorite mod/upgrade (poll)? OCD90 Misc. Chit-Chat 24 February 18th, 2004 05:02 PM
