Does this stuff make my butt look big? Am I over weight? - Defender Source
Old September 15th, 2014, 03:14 PM
coffee's Avatar
coffee
John Oates
1993 NAS Defender 110 #367/500
I have never been on an extended trip where I had to analyze the load capacity in my 110, but want to run this by some of you that are far more experienced. Im assuming the weight is fine, based on some of the photos I've seen of your rigs, but thought I'd draw on the collective expertise of this group.
I want to make sure Im not overloading my vehicle to the point where I could increase trail damage. So here are the weighty items that I will be carrying. Only about 165lbs will be on the roof - the rest will be inside or on a swing-away hitch carrier.
Is this too much weight with 4 200lb guys in the truck? (800 lbs)
1) 2 fuel jerry cans (30 lbs)
2) 4 1.75 gallon roto paks and a 5 gallon auxiliary water tank (100 lbs)
3) a superline cargo area drawer (90 lbs) loaded with air, recovery stuff, etc so more weight
4) 2 hannibal awnings - combined weight prob less than (100 lbs)
5) SD roof rack
6) tuffy winch mounted on front bumper, along with 48" hi-jack
7) 2 spares - one rear door and one top or bonnet
8) yeti 1250 (100 lbs)
9) loaded NL fridge. (55 lbs empty) plus a few cases of beer, of course
So, that puts me at 1320 lbs, plus racks, winch, jacks, spares, full fuel and all the camping gear, tents, more coolers and bags which puts me over the GVWR of 6504 - is that a concern? I think my rear springs are HD, though they've been on there since 99. sorry for the stupid question, but the roads will be pretty rough and I don't want to be so overloaded that I screw something up.
Old September 15th, 2014, 03:23 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
You need a Sankey!
Old September 15th, 2014, 03:30 PM
That would be excessively heavy for paved roads crossing Kansas. Rough roads is beyond that. You are past the limits IMO on brakes, driveline and your suspension.
You want a wide safety margin if you are doing any kind of overlanding. you didn't say where you are going, but the fact that you are thinking of 2 spare tires tells me you are doing extended overlanding on unimproved roads in remote areas. As a practice, you should be doing remote travel with two vehicles, not one. Better to spread that load as well.
I would not go past listed GVWR unless I know for sure I have upgraded my brakes, my driveline is it great condition and that your springs and tires are rated for the load.
I have been in a constant state of evolution with my overland kit which is my goal for my rig, and I am constantly focused on evaluating everything to justify it's weight, and always on the lookout for gear that can do the same job with less weight penalty.
tells us more about your trip, to justify a trip requiring two spares (unlikely in the US), you don't have enough water for 4 adults, you probably are carrying too much fuel for the weight cost, and you should seriously consider leaving the yeti since you have a fridge. your meal planning should focus on backfilling your drinks and increasing your non-perisheable foods.
yes, you are on track to screw something up as is.
Mark Kellgren
KM4BOR
Old September 15th, 2014, 03:43 PM
coffee's Avatar
coffee
John Oates
Thanks for the quick reply. That's what i was afraid of. And yes, I do need a sankey, but I've already pitched that to the family chief accounting officer and it was rejected.....
OK, Im dropping the two biggest friends and putting them in their own car, leaving a cooler behind, and may drop a spare. Hopefully that will be enough to manage. That drops 700 lbs. Thanks for the advice
Im going to the backcountry of big bend national park- so not too crazy and not technical, but there are sometimes bad washouts and a few areas that get rough. I can likely get by with one spare - its just so remove that Im concerned about the nearest shop being a couple of hours away.
Im taking a lifesaver jerry can and can refill and purify water as we go. I didn't think about taking less gas, but that's a good suggestion. I could drop the battery generator - but not much else. the drawer is heavy, but i need it for security since we are camping right by the rio grande. there have been a ton of recent car break-ins
I appreciate the feedback - very helpful
Old September 15th, 2014, 03:54 PM
a better use of weight would be a pair of tire irons and a tire patch kit. with a little knowledge, you can easily repair all punctures except a major tear in a sidewall. if you blow out a sidewall, that is your trigger to go to nearest town to replace a tire.
if you are very remote, rethink your water. it is the most critical item to life. you need to be sure that there is water easily accessible whereever you go if you are going with that little. boiling is your failsafe purification. you should consider water bladders. very little weight, and you don't fill them til just before you head off road.
as for fuel, think of it like a pilot. keep your tanks as empty as you can until just before you leave the pavement and services, then transfer from highest center of gravity supply down. and do the math on your range. if you are traveling 100 miles off road, you don't need 500 miles of fuel. that's just unnecessary weight punishing your suspension and powertrain.
Mark Kellgren
KM4BOR
Old September 15th, 2014, 03:57 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Liquor is lighter than beer!
Also you might consider ditching the drawer system for some soft bags; unless that 90#s is the total weight
Old September 15th, 2014, 04:03 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Don't tell the wife!
Just do it!!!
Old September 15th, 2014, 04:59 PM
coffee's Avatar
coffee
John Oates
I'd love to ditch the drawer - I usually don't use one, but I need it for security near the border. I do like the suggestion to switch from beer to liquor. now that its cooling off, a bottle of bourbon might be a good solution. problem solved
Old September 15th, 2014, 05:55 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
The drawer won't help...they will just tear everything up more to get to it. When are you leaving?
Old September 15th, 2014, 06:02 PM
What kind of man doesn't have his secret toy slush fund?
Old September 15th, 2014, 06:04 PM
Bill Larson
Bill Larson
The same kind that needs it to be a secret! lol...
Old September 15th, 2014, 06:15 PM
coffee's Avatar
coffee
John Oates
I couldn't agree more, Rocky. I thought I had one, but it was quickly depleted once I started getting old whitely in fighting shape for the trip. Lesson learned, I need a bigger slush fund.
Bill - Im not going until October - should be perfect weather that time of year. I've only been in the spring - Last time we did the rafting trip from Lajitas and its incredible.
Old September 15th, 2014, 09:25 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Sankey's are cheap, they don't need to be pretty to do the job.
ht
Big pile of LHD stuff (maybe) and Puma stuff atlcruiser The Vendors Loft 4 March 5th, 2013 08:16 AM
Does watching ppl fumble around for the door and window latch make you laugh? Neil McCauley Misc. Chit-Chat 28 February 3rd, 2011 07:45 PM
does anyone make a selectable hubs for a rover TDI Guy Misc. Chit-Chat 17 June 16th, 2006 05:52 PM
Fuel skid pain in butt flippedrover Defender Technical Discussions 59 December 15th, 2004 02:44 PM
