Does the GBR DC front shaft from D1 fit my 110? - Defender Source
Old February 22nd, 2012, 07:55 AM
Sun Traveler's Avatar
Sun Traveler
D. B.
110 Defender Tdi
Does a GBR (DC) front drive shaft off a D1 fit my 110? I have one laying around that has lower miles on it and wanted to know if it will fit my 110?
my truck has a bad front ujoint on the stock shaft and I need to pull it off to repair it and I wondered if the GBR would fit until I fixed the stock shaft or if I should just run the GBR instead?
thank you..
Old February 22nd, 2012, 09:12 AM
It's real easy to replace a uj.
You'll have to measure the shafts
Old February 22nd, 2012, 09:17 AM
It will fit, but not sure how the DC shaft will do with a stock ride height...
Old February 22nd, 2012, 10:34 AM
I don't think 300tdi and V8 driveshafts will be the same length.
Old February 22nd, 2012, 01:37 PM
300tdi and V8 are the same, the 2.25/2.5/200tdi are different. It should fit.
Old February 22nd, 2012, 02:58 PM
Actually what Ron says makes sense since the tunnel & shifters appear to be in the same place. But, since it only take a few minutes to change a u joint, why bother installing another shaft? Just take out the bad one, fix, and re-install. unless the shaft itself is fubar'd.
Old February 23rd, 2012, 07:29 AM
Sun Traveler
D. B.
110 Defender Tdi
The GBR shaft is on and working fine... I will repair the stock shaft as soon as I get the joints as I have a small order of parts coming in..
NAS 110 front Brake lines pictures/diagram tomaco1 Defender Technical Discussions 0 January 26th, 2011 10:10 AM
110 front brakes on a 90 Muscat Defender Technical Discussions 9 April 10th, 2008 12:14 PM
Help! Question about front rotor and drive shaft. DesertRat Defender Technical Discussions 5 October 24th, 2005 07:14 AM
D-90 and 110 Front Rubber Mats Mike M The Vendors Loft 0 November 4th, 2004 09:39 AM
GBR 4.75 3rds and Extreme front axle setup for sale billnsandi For Sale - Parts 2 January 4th, 2004 11:10 PM
