Does STC1856 replace ignition module? or just move it? - Defender Source
Old July 17th, 2006, 08:08 AM
btate
Bryan Tate
d90
I am having problem with idle, it was searching up and down. Replaced stepper motor and now once the vehicle is hot it will not hold idle at all. (it cuts off)
I have a 94 and the ignition module has not been moved. I was thinking that's one more thing to check off the list. (I don't mind replacing/upgrading along the way if it helps later)
Does the STC1856 only move the module? or is it a new one??
If it is "broken" I wonder if moving it will help?? or is it just tired of being cooked and moving it will keep it cool?
If the relo kit is about $250 and I may need a new module then should I just get an MSD box and new distributor and rule out some other problems???
I wonder how likely the ignition module is my problem.
My mechanic thinks the air intake gasket/seal are leaking once the vehicle is hot??? (just be a phone call, he has not seen it) but that gets to be a pricy fix.
Thanks for any ideas
Bryan
ac, mod
Distributor OR Ignition Module? tdn Defender Technical Discussions 12 December 7th, 2010 12:52 PM
Ignition Amplifier Module Relocation Kit (STC1856) jimngo For Sale - Parts 27 November 23rd, 2010 07:52 PM
Ignition Module Relocation: Help JRowe Defender Technical Discussions 21 March 7th, 2004 11:45 AM
Ignition Module and Coil? milli Defender Technical Discussions 13 October 29th, 2003 01:43 PM
