Does everything look ok under here to you guys? - Defender Source
Old May 20th, 2014, 09:59 PM
svxaddict
Defend Nature
coming soon
Potential new d90
ID:	95500   Click image for larger version
ID:	95502   Click image for larger version
ID:	95504   Click image for larger version
ID:	95506   Click image for larger version
ID:	95508   Click image for larger version
Old May 20th, 2014, 10:06 PM
The pictures don't really show the real problem areas. It looks like it doesn't have much rust, but its really hard to tell without seeing the problem areas such as the rear cross member, bulkhead, and doors. One swivel ball is starting to leak and the other one probably isn't far behind.
Old May 20th, 2014, 10:59 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Based on those pictures alone it looks too good. How is the bulkhead, frame rails, crossmember? Miles? Location?
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old May 20th, 2014, 11:31 PM
Looks like it's landed hard on the rear crossmember.
Some overspray on wiring so it's had some tweaking. May have been power washed
Old May 21st, 2014, 02:29 AM
98 50th anniversary RHD D90 V8 auto?
Looks nice to me.
Old May 21st, 2014, 03:21 PM
svxaddict
Defend Nature
coming soon
the common problem areas are fine, yes evilfij you are correct!
Old May 21st, 2014, 03:46 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Looks nice to me.
And you could tell that from those pictures?? lol
Leaky balls don't matter much unless you want to use it to haggle them with.
Maybe still has oil in the swivels(instead of one-shot).
Rent my
Old May 21st, 2014, 04:39 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Panhard rod and drag link are set up for a RHD configuration, and the black valve cover with visible injector plug is a pretty solid giveaway for a 4.0 GEMS V8. Unless someone converted an NAS truck to RHD it's almost certainly a 50th AE.
In the pictures it looks solid, though as others have mentioned, the problem areas aren't well documented. The front half of these trucks are almost always preserved since they're covered in oil. The gusset on the rear crossmember is in good shape, and they normally crumble to bits when the rest of the crossmember is bad, so that's a promising sign. I'd want to see more before I could comfortably make a decision.
-Ash
Geared Restoration Co.
352-572-3236
Old May 21st, 2014, 04:50 PM
I am the parts ninja.
Old May 21st, 2014, 06:13 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Looks good from here. was any undercoating ever sprayed on it?
Robert Deniro
Old May 21st, 2014, 06:24 PM
svxaddict
Defend Nature
coming soon
Don't believe so
under $100 gift, for the guy who has everything ontheway Misc. Chit-Chat 30 April 29th, 2014 01:07 PM
Something for the bike (bicycle) guys with a teaser for the Rover guys too! jefhuf Misc. Chit-Chat 9 February 26th, 2013 04:44 PM
stereo doesn't work, but everything else does. rd10014 Defender Technical Discussions 3 April 27th, 2012 02:06 PM
Does this look normal? Front Springs bjf Defender Technical Discussions 9 May 17th, 2009 09:40 AM
This just does not look right... Stmpede Misc. Chit-Chat 8 May 2nd, 2007 12:59 AM
