Does an upgrade exist for 94 Dome Light? - Defender Source
Old March 4th, 2011, 12:30 AM
bd90
94 Arles Blue #1644
I pulled the dome light assembly to check the bulb size. Was thinking about replacing it with an LED. When I tried to replace the assembly I found that it would not stay in the opening. It keeps falling out. Anybody else had this problem or is there a good fix or an upgrade available for purchase somewhere?
Old March 4th, 2011, 12:33 AM
bjf's Avatar
bjf
barry f
94 ST #395
The little snaps crack off. Put some tape on the sides to make it a bit thicker and it should stay in.
Old March 4th, 2011, 12:52 AM
bd90
94 Arles Blue #1644
Yeah, that came to mind but was hoping to avoid the low rent fix route.
Old March 4th, 2011, 01:10 AM
bjf's Avatar
bjf
barry f
94 ST #395
I don't think they make the lens anymore
Old March 4th, 2011, 04:11 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Does it look like this?
AMR3155
Or this?
STC251
Both still available.
Tony
1984 110 "Smokey" (sold)
Old March 4th, 2011, 10:12 AM
bjf's Avatar
bjf
barry f
94 ST #395
Nope neither are correct
Old March 4th, 2011, 11:10 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
If you look long enough it can be found, but it's not worth the effort. Change over to an LED bulb and secure the lens with a tie wrap that goes completely around the light. With an LED you will never need to get to the bulb again.
Old March 5th, 2011, 08:04 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
You can get the plastic section without the dome light cutout (got one from George at RDS onetime) and you can mount any style you want.
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
dome light, ht
Can I use a Dome light switch for hella lights tebby Defender Technical Discussions 4 September 5th, 2009 11:12 AM
Dome Light / '97 Multi Function Unit GYM Defender Technical Discussions 2 March 6th, 2007 05:53 PM
FYI - a good price for H4 light upgrade harness solihul Defender Technical Discussions 1 May 31st, 2005 11:18 PM
Rear Dome Light Stays On thug1313 Defender Technical Discussions 5 November 1st, 2004 08:33 AM
Head Light Harness Upgrade $30 dnewman9 For Sale - Parts 0 August 1st, 2004 11:18 AM
