Does a 3.9 have a govenor at 3400 rpm? - Page 2 - Defender Source
Old November 22nd, 2006, 12:23 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Sometimes at specific RPM's, if the zeener diodes in the rectifier circuit of the alternator has failed, it will leach A/C current into your wiring causing false trips on the injection system. Mine was at 2700 RPM, but I have heard of other rpm's affecting it.
Old November 22nd, 2006, 03:49 PM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
I am kinda inclined at this point to believe a sensor as well but without a code I have no place to start. I have still not found the issue. Still looking....
Old January 11th, 2007, 10:12 AM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
Well, I upgrade the the distributer and coil to MSD per several recommendations. The D is phenomenally stronger running now but still cuts out completely at 3400 rpm. I am running out of ideas at this point. It seems to have a lot of power at 3000 rpm but stumbles and will not surpass 3400 rpm under any circumstances.
Clogged cats would cause an over heating issue correct? I have none and the D only has 45k miles on it.
I have been unable to locate a fuel pressure gage that will fit the line at the filter so I don't see how I can check the pump. I replaced the fuel regulator with no obvious effect.
Any ideas? This is driving me crazy. It will not reach the speed limit on the interstate due to this, forget passing anything besides grandma on a cellphone.
Old January 16th, 2007, 11:23 PM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
Angry
oops
Old January 17th, 2007, 12:03 AM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Anyone know if there is a 'limp home' mode in the 14CUX ECU?
Doug W.
Old January 17th, 2007, 10:45 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
If the 14CUX ECU is the stock 3.9L ECU, then yes. I would assume that any ECU would have a limp mode in case of sensor failure.
MonLand
1995 D90 NAS
1996 Discovery NAS
Still frustrated - Can't pass 3400 rpm ScottYates Defender Technical Discussions 5 January 17th, 2007 09:16 PM
3.5 to 3.9 install kellymoe Defender Technical Discussions 3 February 6th, 2006 01:24 PM
3.9 to 4.6 1995 D-90 boxerhips Defender Technical Discussions 5 January 25th, 2006 07:20 PM
3.9 parts Mike Hippert For Sale - Parts 2 September 7th, 2005 02:29 PM
RPM Fluctuation Billakris Defender Technical Discussions 5 March 28th, 2005 10:52 PM
