Do you have to replace the tappet slider retaining bolts - Defender Source
Old November 13th, 2016, 08:43 AM
Sandy Landy's Avatar
Sandy Landy
RCer
97 Defender 110 300TDI S
Hi Guys,
Just skimming though the torque specs for my 300tdi head bolts and saw the manual stating that the tappet slider retains bolts be replaced...is this totally necessary?
Mine are in perfect shape, threads perfect and no corrosion or deformity, wonder why they are one time use bolts.
I usually do everything by the book but this has me wondering and besides that, don't know if it's available locally.
Cheers.
Old November 13th, 2016, 09:27 AM
I can't see any valid reason to replace them. They need thread lock.
Old November 13th, 2016, 09:31 AM
Sandy Landy
RCer
Agree Bud, thanks, I will reuse them and use red thread lock.
BTW, I came across your landy blog, very informative..awesome.
Cheers Bud and have a good one.
Old November 19th, 2016, 10:15 AM
ugly90
1987 90 ExMod FFR
They are to be replaced as per the manual. They do an important function for the engine, and are very cheap as OEM. Your cam, tappets, followers should all be new OEM during a rebuild. You can reuse the steel holders if they have no wear on the inside. No threadlock reuse fix on old tappet retainer bolts. The threads on all bolts are designed to deform when torqued, no guarantee on those used ones. You're not saving any money reusing them. Same applies to conrod nuts should be new high grade ones. Toss the old ones away.
Old November 19th, 2016, 12:17 PM
The_Vermonster's Avatar
The_Vermonster
Gordon
1984 110 CSW
Internals of the engine is one of the last places I would want to be installing used parts. For something so cheap, it would be silly not to use new ones.
ac, bolts, slide
Injector Replace / Rebuild / Nozzle Replace icnsltmfg Defender Technical Discussions 8 April 29th, 2015 08:29 PM
Replace Broken Bolts on LT230 Rear drive Flange-I must be missing something. 95beluga Defender Technical Discussions 4 March 8th, 2015 04:25 PM
help needed, tappet Ignotus Defender Technical Discussions 0 August 11th, 2013 02:57 PM
Heads that only have been rebiult once need to have tappet/lifter gap checked? Neil McCauley Defender Technical Discussions 4 December 14th, 2011 03:19 PM
Tappet/lifter tolerances after rebiulding heads Neil McCauley Defender Technical Discussions 3 January 18th, 2007 08:28 AM
