Do you confirm? - Page 2 - Defender Source
Old April 14th, 2013, 06:42 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
X2 on Ron's post. Locking the T-Case and pulling the front shaft will get you by until you can change the tires for ones that match in size. If you don't you run the risk of shearing the cross pin in the T-Case diff as its not designed to handle that much F&R speed difference for extended periods.
Remember you will have a rear wheel drive only truck only in this set up until you correct the tire issue.
Ian
Old April 14th, 2013, 06:58 PM
Originally Posted by evilfij View Post
Lock center diff and pull front drive shaft.
Okay
Old April 15th, 2013, 12:12 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Yep, that'll work. If it were me I'd still be dropping the transfer box oil to check for filings. That oil's done quite a bit of work, fresh EP90 won't hurt.
Mike Hammond
Can Somone Confirm - VDO gonzanc Defender Technical Discussions 9 December 31st, 2012 03:31 PM
I tthink my starter is almost toasted, can someone confirm? jayz Defender Technical Discussions 5 September 8th, 2012 10:56 AM
Can anyone confirm that a 95 Disco 1 came with a rear limited slip CDeWan Defender Technical Discussions 7 January 22nd, 2009 03:49 PM
McCain taps Alaska gov. Sarah Palin as VP, officials confirm zimm Misc. Chit-Chat 18 August 31st, 2008 12:57 PM
trying to confirm tire size needsaD110 Misc. Chit-Chat 3 December 20th, 2006 11:51 AM
» Defender Registry
D90
griffinrr
Crusty
andy110
Add your Defender
