Do the clips have a name? - Defender Source
Old June 8th, 2013, 03:20 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
What do you technically call the plastic clips that insert in these type of stamped cut out or holes allowing you to screw something to it?
The trim kit around re headlights requires me to screw in to these holes, and I'm not sure what to ask for when I'm calling around to auto supply places.
TIA
Old June 8th, 2013, 04:15 PM
transientmechanic's Avatar
transientmechanic
1972 SIII
You will have a very hard time finding the right ones from a generic auto supply store, I would just order them from RN or even better RDS for a few bucks.
Old June 8th, 2013, 04:20 PM
jafir's Avatar
jafir
Jafir Elkurd
Other than pounding out the dents and installing these clips, is anything else required to put headlamps surrounds on an ex-mod truck?
Old June 8th, 2013, 04:36 PM
josh-man's Avatar
josh-man
joshua
I'm in the thick of it but AB sold me the kits. You could stay with the MOD lights but I opted to but the NAS lights too for the front. Just need those clips, the lights and a quick require of 8 wires.
The only wild card is the headlamp bowls which I was TOLD by AB needed to be changed too, but as far as I can tell there is zero reason to do this.
------ Follow up post added June 8th, 2013 04:37 PM ------
RDS? School me.
Old June 8th, 2013, 05:22 PM
josh-man's Avatar
josh-man
joshua
If you are using the defender plastic surrounds, be aware that the location and size of teh lower hole (blinker) changed in size and location over teh years.
-Jeff
Yes, Jeff- learned that the hard way. AB sent wrong stuff the first time...
Will call George.
Tailgate bar clips needed pdella Wanted 5 June 15th, 2012 04:29 PM
D90 Rear Tailgate Clips and Bench Seat BMGmotors Wanted 2 March 29th, 2011 01:16 PM
Header bar, yellow hinges, tailgate bar clips mspell Wanted 1 October 4th, 2004 04:20 PM
Have a trashed Bestop soft top? Need tailgate clips, vertical rails, misc. jaherring Wanted 3 September 24th, 2004 09:15 PM
part #'s for clips mattdh Defender Technical Discussions 5 October 10th, 2003 10:13 AM
