do I need to pack the oil pump? - Defender Source
Old September 4th, 2008, 05:30 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Rebuilt the top end. Pan is off, filter is off, cooler lines disconneted from the rad. but I have not opened up the oil pump. Do I need to Vaseline it or am I ok as long as I don't open the pump? Or for good measure should I manually prime it with a socket?
Old September 4th, 2008, 05:51 PM
If you didn't drain the cooler lines, its probably still primed. If it was me, I'd take off the cover and pack it.
Old September 4th, 2008, 06:02 PM
I would not bother, but be ready with to prime it manually. If you have a drill bit set up, I would do that before starting, but I would not bother if you have to make the bit.
Old September 5th, 2008, 09:26 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I believe a 14mm socket works
ac
Oil Light Flickering/Oil Pump Glenn_Guinto Defender Technical Discussions 13 October 27th, 2004 08:27 AM
Priming Oil Pump chrism Defender Technical Discussions 3 April 29th, 2004 03:53 PM
