Do I have a trailer wire harness or not!! - Defender Source
Old April 7th, 2004, 12:33 PM
P1CR
Mazen Fawaz
97' D90 SW, Arles Blue
Having read the precious posts on this subject, I have not come to any conclusion.
Some trucks do, and some don't??
Or maybe I just can't find it? I have a 97' hardtop.
any help?
Maz
97' D-90 SW
Arles Blue
Old April 7th, 2004, 01:05 PM
Did you see this ?
It should be right behind the PS rear tire kind of under the gas filler.
Old April 7th, 2004, 07:54 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
The round connector is located in the wheel well as Mike said. You can buy from LR a "harness"; basically a mating connector that plugs into the connector, with individual wires coming out of it. Overpriced (until you realize it's probably hand-built with European union labor, and not some Asian high-volume mass-produced thing), but it'll save you from splicing into the brake/turn signal wires in an area that gets alot of dirt and mud.
For U.S. trailers, you'll then need to get (cheap, from just about any auto parts store), a converter that combines the separate brake/stop signals from the D-90 into a single signal for each side.
94 D90 wire harness & 94 A/C wire harness mdmuf Wanted 1 August 24th, 2007 09:33 AM
Trailer harness plug and/or connector type spoolin440 Defender Technical Discussions 14 October 8th, 2006 04:37 AM
Trailer Wiring Harness Weldon Defender Technical Discussions 17 August 26th, 2004 12:03 PM
