DIY VNT turbo for 300TDI? - Page 2 - Defender Source
Old April 12th, 2011, 05:07 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Still no word from IRB....
Old April 13th, 2011, 03:18 AM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
So I emailed him again after posting today, and voila! an answer:
Apologies for being a pain to get hold of....
300Tdi Turbo... I will chase up today - still awaiting a final delivery date from the the turbo manufacturers.
They were supposed to be ready for the end of March, but I think this has moved back slightly.
The turbo is a direct for swap for standard, the only change is the oil return line, but a new one will be supplied in the kit.
So, it looks like he'll have a kit for sale very shortly. I'll post when it is.
Old April 13th, 2011, 12:31 PM
T1G UP's Avatar
T1G UP
marcus
Puma 110 xs. Td5 110 xs for sale
keep onto Ian, he'll forget!
2011. 110 XS SW. 1999 TD5 110 XS SW Project For sale
Santiago Montenegr's Avatar
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
Thanks! I am really looking forward to such a kit.
Old February 27th, 2012, 08:59 PM
8 mos later any fruit falling from the tree ?
Old March 4th, 2012, 12:08 PM
the 2.8 is everwhere down here. James from NLX said he saw a used vnt for $250 US a little while ago. You could by a whole 2.8 used in these parts. we're onto something now.
Mark Kellgren
KM4BOR
Old March 4th, 2012, 02:59 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Interesting.
Legend in My Own Mind.
Old November 1st, 2012, 12:49 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Any new developments here? I'm seriously considering ordering a kit. Just haven't decided where to get it from.
Old December 5th, 2012, 11:03 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
My kit arrived this week. Does anyone have a photo of where you installed the sender for your EGT gauge (if you have one)?
Any other tips or suggestions I should know about before installing? Do I need to drain the engine oil in order to install this?
Old December 6th, 2012, 08:11 AM
you have the 2.8 intake manifold? if so, I posted a pic of my EGT probe install a while back with a pic. If you can't find it, I can retake it.
Not sure if you have to re have repace oil supply line, but it's above the sump so you shouldn't have to change oil, but be sure you prime it before first start!!! that's disconnecting wire to fuel stop solenoid and turning pver until you get good oil pressure.
Mark Kellgren
KM4BOR
Old December 6th, 2012, 08:59 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I believe I do. It's the complete kit. Do you remember which thread you posted it under? I've done a brief search. Is it the "International 2.8" thread? I will dig deeper...
Thanks for the heads up on the priming.
Old December 6th, 2012, 09:13 AM
here you go: http://www.defendersource.com/forum/...t=probe&page=2
the manifold is thick enough right there to not need a bung welded on it, and it's pre-turbo, so you don't have to do math when you read the gauge.
------ Follow up post added December 6th, 2012 09:15 AM ------
BTW, when I asked about the manifold, I meant exhaust manifold, not intake.
Mark Kellgren
KM4BOR
Old December 10th, 2012, 12:30 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Mark did you install a Turbo Boost Gauge as well? If so, can you tell me the part number for gauge and sender? Too many options on the egauges site and I'm not sure what is appropriate for this particular turbo.
Old December 11th, 2012, 02:17 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
What kits are out there for the 300 now? Is it just a turbo or other parts too that are needed.
Old December 11th, 2012, 02:27 PM
you want the kit that has gauge and sender complete, and the gauge covers the temp range you want and the gauge fits stock gauge hole in dash ( 2 1/16"?). my gauge reads 250-1650 F. looks like kit 310-153 to me.
Mark Kellgren
KM4BOR
Old December 11th, 2012, 03:52 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Late reply,
here's mine:
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old December 11th, 2012, 04:36 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
You're thinking about the pyrometer (EGT) right? I already have that kit purchased and ready to install. I was considering installing a Turbo Boost gauge as well. Those read in PSI and BAR to my understanding. Do you have one of those, if so, part # and where did you install sender?
Old December 11th, 2012, 04:39 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks!
Is that the exhaust pipe after the exhaust manifold? Looks like you welded it? Won't the temp be lower when it's further away from the manifold? I would think that the closest possible location to the engine would give the most accurate reading. Perhaps it doesn't matter?
Originally Posted by Cube II View Post
Late reply,
here's mine:
Old December 11th, 2012, 05:17 PM
Cube II's Avatar
Cube II
Michele
1997 D90
It was TIG welded, and yes, right after the turbo.
The manifold was already in place (well the whole kit installed) when I got my EGT kit, and I wanted to pull it again...
I get a clear indication of what's going on down there, I know there's some difference in the reading compared to the before-turbo position, but I just drive accordingly.
A few more pics here:
http://www.whitedogrover.com/vnt.html
VDO boost gauge location:
http://www.defendersource.com/forum/...ad.php?t=39892
Michele
D90 VNTdi
[O]===[O]
Old December 11th, 2012, 09:57 PM
Originally Posted by turbodave View Post
What you do get is a turbo that is very well proven at 30+PSI levels, has a highly efficient compressor and turbine and is a lot cheaper than any VNT.
One shame is that Garrett's smallest frame cartridge ball-bearing turbo is the GT2554R in the T25 frame.
300tdi, tdi
Turbo factoid Overlander Defender Technical Discussions 2 January 15th, 2011 01:32 AM
My turbo is dead :( Overlander Defender Technical Discussions 48 December 16th, 2010 09:08 PM
DIY Rock Sliders kellymoe Defender Technical Discussions 3 December 22nd, 2005 07:10 PM
remote turbo? Rod Hayward Defender Technical Discussions 7 January 11th, 2005 04:16 PM
Need rear brakes...DIY?? P1CR Defender Technical Discussions 17 March 6th, 2004 03:46 AM
