dixon bate hardware question - Defender Source
Old April 9th, 2008, 05:34 PM
cneal
Charles Neal
97 d-90, 99 & 04 disco's
I just bought a Dixon Bate 5.0 Ton Tow Jaw from EE. Came without the mounting hardware. Does anyone know what size bolts I need for a 97 D90?? John @ EE said he used 1/2 inch (M12) but did not remember how long they were.
Old April 9th, 2008, 05:43 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
don't forget a backing plate
3rd low and BOOT IT
Old April 9th, 2008, 07:20 PM
cneal
Charles Neal
I have the backing plate, just need the hardware.
Old April 9th, 2008, 08:53 PM
4x4sche
john
73 SIII_ 97 D90_94 Disco
Why do you need ME to go out to MY truck and measure what bolts you need. Why can't YOU go out to YOUR truck and measure it yourself. And while your out there look up for me how many quarts of oil I need for my next oil change.
J.
Old April 9th, 2008, 09:53 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
J.
J.
I hope this post is a joke right?
Jimmy Buffett
Old April 9th, 2008, 11:51 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
I guess it depends on how thick your bumper is, that is if you are mounting it to the bumper. Take the bumper thickness + backing plate+ Dixon bate thickness and leave yourself room for the nut to get all the threads on. If it's behind the bumper, then it can be a little longer and nobody will ever know. I took the DB to the hardware store and got some big ass grade 8 bolts and washers.
Old April 10th, 2008, 10:49 PM
discotdi
Todd Miller
Land Rover
The one I bought from Rovers North came with all the bolts etc. It had a LR part number. Might want to try them next time. Mayeb they can provide the correct bolts.
Old April 11th, 2008, 03:55 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Why do you need ME to go out to MY truck and measure what bolts you need. Why can't YOU go out to YOUR truck and measure it yourself. J.
Because they don't have rulers in Utah?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 11th, 2008, 04:06 PM
Tawayama's Avatar
Tawayama
Michael Slade
No Land Rovers
He could come over and borrow mine.
Michael Slade
www.tawayama.com
Old January 11th, 2010, 12:19 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Dixon-Bate (3.5t) install location on ARB Bumper.
For those of you who have installed a pair of Dixon-Bate Tow Jaws or mounted a similar recovery points to your ARB bumper, where did you install them exactly? I had two Curt MFG hooks already installed in a bit of an odd spot (see white cross on attached picture) when I got the rig and ARB told me that they didn't approve of that location because it wasn't considered safe (the bumper could fail). Now they got me all worried so I thought I'd ask around to see where people installed their recovery points and if you've had any trouble using them where you put them. The two potential areas I've chosen are marked in the photo (red). They are more or less to the left and right (closer and further out) of the winch. Does it matter where? I just wanted to make sure in case there are some specific rules to follow. Thanks!
Old January 11th, 2010, 05:56 AM
Antichrist's Avatar
Antichrist
Tom Rowe
That white 'x' does seem to me to be a very poor location.
I always try to mount them in line with the chassis rail.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old January 11th, 2010, 09:23 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
6 inch X 1/2 grade 8 or better.. its best to drop the tank its tight if you are just reach up.,
that way you can clean and paint the back of the cross member while you are at it.... MIGHT AS WELL ...MAW
Old January 11th, 2010, 01:00 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
It was. I removed them. Seems like you would want it lower and more in line with the chassis rail of the bumper.
I could put them right next to the winch roller fairlead but there is an overhang that might interfere with it. I'd rather put them further out but still horizontal to the chassis rail (the furthest to the left/right in the picture I posted). Close to the ARB logo. This location would be alright, wouldn't it? It would horizontal but not right next to the chassis rail.
Old January 11th, 2010, 02:01 PM
Antichrist's Avatar
Antichrist
Tom Rowe
I'm not familiar with the ARB bumpers for Defenders, but just based on the photo I'm guessing I'd go with the outboard location you have marked.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old January 11th, 2010, 02:02 PM
Inside the rail is probably stronger than outside, but either way get as close to it as reasonable, use a backing plate, and you'll be fine.
Originally Posted by pendy
I'm here for the D's
Old January 12th, 2010, 10:17 AM
Antichrist's Avatar
Antichrist
Tom Rowe
The reason I said outside is because 90% of my loads on a front recovery point are when winching with a snatch block. Inside all the bending forces are trying to pull out the center of the bumper. Outside there is a counter force.
Probably over thought and in reality probably make little difference.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old January 12th, 2010, 11:57 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
That's pretty much was I was going to use it for. I think you're right. Its a really beefy bumper so I don't think you can go wrong so as long as it is located horizontally level in comparison to the chassis rail. If it is like those hooks that were (higher up) then potentially some leverage could be created and twist the bumper. I will install it on the on the outward location, pretty much exactly where the recovery point is on the Defender (the D-90 source background picture) to the left of this text.
Jump Seat Hardware Question Stmpede Defender Technical Discussions 2 February 28th, 2009 02:43 AM
Bushing hardware question D90user Defender Technical Discussions 3 November 30th, 2005 03:54 PM
Bolt length needed to install Dixon Bate ronward Defender Technical Discussions 2 September 11th, 2004 06:05 PM
