Distributorless (direct ignition) system - Defender Source
Old November 10th, 2008, 05:07 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Has anyone tried converting their D90 to a direct ignition system, ie crank sensor, etc to get rid of distributor?
I know you still need the distributor gearing to run the oil pump but you could at least get rid of the electronics making it more waterproof and more adjustable.
Old November 11th, 2008, 08:36 AM
Tim Scully's Avatar
Tim Scully
Tim Scully
95 D90 SW/ 95 RR LWB
I have done it but I had a parts car to rob all of the computer and wiring harness components. Also depending on the year of your motor you probably need the port in the rear of the block for the crank sensor! When I swithced over I used the complete motor with ancillaries from the donor vehicle.
Old November 11th, 2008, 01:44 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Did you use or splice into the D90 ECU or just use the control system from the company that you used for the direct injection system??
Have you been happy with it??
Thinking of using XDI system from Electromotive but not happy over scrapping the ECU and going with total after-market total control system.
distributor
Ignition? Trigger Defender Technical Discussions 12 August 1st, 2005 08:53 PM
different ignition options vesparover Defender Technical Discussions 5 December 5th, 2003 03:02 PM
rail system hooks & anchor point mounts paulb Defender Technical Discussions 2 November 24th, 2003 01:16 PM
