Distributor Vacum Advance - Page 7 - Defender Source
Old February 9th, 2010, 01:09 PM
Hey not trying to advocate throwing parts at it, but in lieu of spending more on shop hours, I'd consider replacing the VSS and ignition control modules if you haven't yet. Cheap enough and good to replace for the future anyway. Next would check grounds on the fuel circuit.
Old February 9th, 2010, 01:12 PM
bjf's Avatar
bjf
barry f
94 ST #395
VSS?
I really haven't thrown money at it. I bought an ECU for 75 bucks so not so bad. I thought about ignition module but the RPM going up and down and the fact it restarts easily if it stalls points to it not being that.
Old February 9th, 2010, 01:15 PM
Vehicle Speed Sensor
Old February 9th, 2010, 01:22 PM
bjf's Avatar
bjf
barry f
94 ST #395
where is it?
Old February 9th, 2010, 01:42 PM
http://tinyurl.com/yas5pso
Old February 9th, 2010, 01:46 PM
bjf's Avatar
bjf
barry f
94 ST #395
Charles,
This link is awesome and amazingly douchey. I will be using this technology on Horsey.
Old February 9th, 2010, 01:49 PM
I aim to please
Old February 9th, 2010, 01:53 PM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
Originally Posted by bjf View Post
where is it?
I mentioned this in post #110 of this thread
some call it VSS and some call it just speed sensor or VSS Transducer
Charles bet me to it...
I still think that it is a pinched hose of some sort in your fuel line, or something in the tank (like your bong)
maybe a lose or bad connection with the wires for the fuel pump
and I don't mean beer bong either
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old February 9th, 2010, 01:54 PM
bjf's Avatar
bjf
barry f
94 ST #395
Would the VSS do this? I also think it is something fuel related.
Old February 9th, 2010, 02:11 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
You know whats wierd is last nite my D90 started developing some kind of slight hesitation then stalled out on me at a red light. It happened right after I filled the tank, then it started right back up with no problems. I think it might of been dirty gas? Its been running fine now since so I don't know what happened, interested in this vss thing you guys are talking about.
Robert Deniro
Old February 9th, 2010, 03:52 PM
ignition module.
Old February 9th, 2010, 04:06 PM
bjf's Avatar
bjf
barry f
94 ST #395
the ignition module really would make the rpm go nuts like it is choking?
how much is one and can i just get a new one and plug it in
aosias's Avatar
aosias
Alexandra
1995 D90
How much fuel have you gone through since all of this started?
My BMW did this and I used a fuel additive, got it from behind the counter at Napa, and it cleared it up. Ran it through my 90 too just for kicks. If you want I'll look around for it, I wrote it down somewhere, the tech at BMW told me to give it a try since they couldn't diagnose anything that was causing the engine to rev up just a bit. Apparently my @ss isn't a good enough diagnostic tool for them, and seeing it on the guage.
Old February 9th, 2010, 04:09 PM
bjf's Avatar
bjf
barry f
94 ST #395
at least 6000 miles. I tried the LR fuel additive
Old February 9th, 2010, 06:17 PM
Abeer's Avatar
Abeer
Amarveer
94 D90 ST
My 90 was acting up for a little while. At idle the truck would shake and between 1 and 2000 rpm it would sound like it was suffocating and was stumbling. It would also occasionally stall at idle and stumble or almost stall at a slight push of the gas pedal. I took it to the shop thinking it the 02 sensors were out (previous owner records showed a similar problem that a new 02 sensor fixed). Shop found the 02 sensors were basically caput and replaced them.
Truck ran great for 3 weeks then I had 2 random no starts and the car sounded like it was gasping for gas at startup every now and then. I was also still experiencing almost stalls when softly pressing the gas pedal but the absolutely rough idle and the stumbling between 1 and 2k rpm were gone. I thought it was a fuel problem but knew my relays and fuel filter had been replaced at the 60k service and was sure my fuel pump was fine.
It went back to the shop for a clutch replacement and they found a small leak in one of my lines. I have to check my records to find out what leak it was but since then (200 miles) I have had none of the issues I had before.
I don't know if you were experiencing any of these issues but the new 02 sensors and leak seal fixed my stumbling/stalling problem. I thought for sure it was a fuel issue but those 2 fixes took care of it. I'll check my records tonight and see what the leak was again.
Hope this helps or gives you more annoying things to check out
Old February 9th, 2010, 06:25 PM
bjf's Avatar
bjf
barry f
94 ST #395
hmm will check
Old February 9th, 2010, 09:31 PM
bjf's Avatar
bjf
barry f
94 ST #395
Sweet truck is now worse. Used to only do it when it was warmed up now it does it all the time. Might be easier to figure out. I drive, press clutch and it wants to stall
Old February 9th, 2010, 10:02 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
The speed sensor (VSS) keeps the motor running when you pull to a stop. My understanding is that it tells the computer to give the motor more fuel when your speed slows.
I'm not sure if your symptoms match up to it exactly, but I think it was relatively cheap and fairly easy to replace. Mine was stalling when I would come to a stop and put the clutch in unless I stayed on the gas.
Edit: Mine also gave code 68 when the VSS when out.
Old February 10th, 2010, 02:11 PM
bjf's Avatar
bjf
barry f
94 ST #395
I solved the problem. I stopped driving it. Kidding. I will check the VSS
thanks
Old February 10th, 2010, 04:56 PM
bjf's Avatar
bjf
barry f
94 ST #395
Air Flow Meter?
ac, distributor
TORX Vacum Advance rover4x4 Defender Technical Discussions 3 June 18th, 2009 09:06 PM
vacum advance rover4x4 Defender Technical Discussions 1 June 2nd, 2009 08:08 AM
vacum advance hoses rover4x4 Defender Technical Discussions 0 November 17th, 2007 12:12 PM
Vacuum Advance Andrew Vick Defender Technical Discussions 11 April 27th, 2007 08:25 AM
Vacuum Advance CGunther Defender Technical Discussions 0 September 28th, 2006 12:52 PM
