Distributor Vacum Advance - Page 6 - Defender Source
Old February 6th, 2010, 12:20 PM
bjf's Avatar
bjf
barry f
94 ST #395
I have not heard that one. Got a new ECU last night. Once it stops raining I will put it in. On that note was there a speed limiter on the defender ecu. The guy I got the ecu from said there was and the one he gave me doesn't have it. Not that I would go faster than 75 in the 90 anyway.
Old February 6th, 2010, 07:45 PM
bjf's Avatar
bjf
barry f
94 ST #395
Went to switch the ECU and noticed the little computer screen in car shows code 2. Not sure it is related or not. I think it means the power was interrupted.
thanks
ECU is in. Since the issue is so random not sure how long I need to wait to see. I will say my truck still does a stepped idle though.
Old February 6th, 2010, 09:21 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Code 2 is exactly that, a power interruption.... should be cleared the next time you started it up. nothing to worry about.
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 6th, 2010, 09:50 PM
bjf's Avatar
bjf
barry f
94 ST #395
thanks. So with both ECUS I have the slightly stepped rpm drop at lights. I haven't driven this one enough to say the problem is gone but as Ron pointed out it would not change the step RPM. Is that just the way some trucks are. I think I notice it more because of the borla being loud. My 110 I can't tell if it is doing it but it appears to not be.
Anyway that is beyond minor, I just want the erratic RPM that happens with the occiasional stall to go away. Next with be ignition coil I guess or fuel pressure test.
Old February 8th, 2010, 11:21 AM
JPBrown's Avatar
JPBrown
James Brown
91 & 2000-110 -93 130 wagon, 88 d90
I don't think that is just how some trucks are, I have three other 90's and none of them have ever run how the one I'm in now is. It is at a new shop today and hopefully they can come up with a solution. Hope you have some luck with yours!
Old February 8th, 2010, 12:43 PM
bjf's Avatar
bjf
barry f
94 ST #395
Well we are talking ab out two different issues. One issue (the main one) is the stalling and RPM drop at lights and kick back up. That is the big problem. The other issue is when I get to a light the RPM drops to about 1000 for a few seconds then goes to 800. Two shops have told me this is normal regardless of the ECU I have.
Old February 8th, 2010, 02:02 PM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
mine does that for the first 10 min. or so of driving, maybe a warm-up cycle
as for the other, have you changed the speed sensor? not sure if your symptoms are related to that part...
the throttle position sensor will through a check engine code if it is bad, so must not be that
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old February 8th, 2010, 02:11 PM
bjf's Avatar
bjf
barry f
94 ST #395
Yeah not that. This issue happens after driving for about 20 to 30 minutes on occasion. Sometimes it stalls but more the RPM dropping to about stall and kicking back up.
Old February 8th, 2010, 02:13 PM
You need to hook it up to a land rover computer and check all the sensors to see what they are reading. Not sure if any of these places have a 1994 compatible computer scanner. I know the one the dealer had you could see O2 function, temp sensor, TPS etc.
Old February 8th, 2010, 02:16 PM
bjf's Avatar
bjf
barry f
94 ST #395
where does this magic computer plug in? If it plugs in by the ecu I know they havent done it because the metal kick panel was never removed.
Old February 8th, 2010, 02:17 PM
Jon_Winningham
Sterling M Archer
strange...
long shot here, did you drop the gas tank to see if you have something in there, and did you change the fuel filter?
could be a corroded wire that looks clean
too bad you are so far away, I bet if Kyle got his hands on it he could fix it
------ Follow up post added February 8th, 2010 02:21 PM ------
I know our local LR Center did and may still have one. I got to see it in action about 10 years ago, really cool.
Old February 8th, 2010, 02:22 PM
bjf's Avatar
bjf
barry f
94 ST #395
Because I am a crazy person about 2 years ago I had an issue where when I filled the tank with gas it would stink. I had the smallest of small hairline cracks by one of the tubes on top. So of course I replaced the tank, breather and filler tubes, fuel pump, and the fuel cradle (slick rock). I think the issue started after that. Fuel filter is new as well.
Old February 8th, 2010, 02:25 PM
Jon_Winningham
Sterling M Archer
damn, these Land Rover things have not been cheap for you!
Looks like you have narrowed it down some.
Old February 8th, 2010, 02:27 PM
bjf's Avatar
bjf
barry f
94 ST #395
My fear is the pump is bad. last thing I want is to have to drop the tank again. Well I used to really spend on the 90 when the 110 wasnt making me poor
Old February 8th, 2010, 02:30 PM
Jon_Winningham
Sterling M Archer
I think fuel pumps are either working 100% or not. I bet there is a lose wire or pinched hose. Check all wire and hoses you can access, then drop the tank if you still do not see anything.
Old February 8th, 2010, 02:32 PM
bjf's Avatar
bjf
barry f
94 ST #395
man i dont want to drop that tank.
Old February 9th, 2010, 11:24 AM
JPBrown's Avatar
JPBrown
James Brown
New shop could not come up with anything other than the stepper motor...so he pulled the "new" one the former shop put in and it was finger tight and didn't seem to fit right. It looked new but was made in Mexico? Does this seem normal? He put in a used motor and the truck is running fine, the new motor tightend down like it is supposed to, so I hope this is it.
Old February 9th, 2010, 12:56 PM
bjf's Avatar
bjf
barry f
94 ST #395
Well it aint the ECU. My truck still has the issue. I pulled up to a light today, put my foot on the clutch and it was like I was choking the engine, it jsut wanted to cut out until I stepped on the gas.
Old February 9th, 2010, 01:04 PM
Welcome to January 14th again.
Originally Posted by cgalpin View Post
What happened? You hit a bump and a couple ones changed to zeros?
Old February 9th, 2010, 01:07 PM
bjf's Avatar
bjf
barry f
94 ST #395
Yeah yeah. I guess time to find out the fuel pressure
ac, distributor
TORX Vacum Advance rover4x4 Defender Technical Discussions 3 June 18th, 2009 09:06 PM
vacum advance rover4x4 Defender Technical Discussions 1 June 2nd, 2009 08:08 AM
vacum advance hoses rover4x4 Defender Technical Discussions 0 November 17th, 2007 12:12 PM
Vacuum Advance Andrew Vick Defender Technical Discussions 11 April 27th, 2007 08:25 AM
Vacuum Advance CGunther Defender Technical Discussions 0 September 28th, 2006 12:52 PM
