Distributor Vacum Advance - Page 3 - Defender Source
Old January 28th, 2010, 05:42 PM
Replace the ignition module. Roverguy.com has [or had a while back] New in box genuine for under $100. BTW does yours have the relocation kit yet? If not, see if he has a used one. Hot intermittent dying seems like module or the little black chicklet resistor or whatever it is, but 9/10 I would guess ignition module.
Old January 28th, 2010, 06:04 PM
bjf's Avatar
bjf
barry f
94 ST #395
How can I tell if it was relocated?
Old January 28th, 2010, 08:08 PM
it should be near the coil, there is a little black thing on the side of the distributor about the size of a box of matches. the relocated should be similar to the "thing" on the dizzy on an aluminum plate.
------ Follow up post added January 28th, 2010 08:10 PM ------
http://www.rangerovers.net/repairdet...nitionmod.html
------ Follow up post added January 28th, 2010 08:11 PM ------
I bet this is causing your problem.
Old January 28th, 2010, 09:38 PM
bjf's Avatar
bjf
barry f
94 ST #395
drove home. no stalling but i am back to that stepped idle issue. still think it is the ignition module?
Old January 29th, 2010, 08:18 AM
Id relocate the ignition module if it hasnt been. As far as the idle hunting around a couple hundred RPM's big deal.
Old January 29th, 2010, 09:30 AM
bjf's Avatar
bjf
barry f
94 ST #395
The point is I don't understand the rpm cause. I would assume thry are tied together.
Old January 29th, 2010, 10:51 PM
jhobbs
Jay Hobbs
1995 D-90 SW LRNA/10 (**sold**)
My 95 SW is doing the exact same thing. Once it warms up it will sometimes surge when I come to a stop. Is your check engine light on? I am throwing code 44. Had a couple of things replaced, next on the list are both O2 sensors.
Old January 30th, 2010, 09:53 AM
bjf's Avatar
bjf
barry f
94 ST #395
No service lights. I am taking it to a different shop tuesday.
Old February 3rd, 2010, 04:27 PM
bjf's Avatar
bjf
barry f
94 ST #395
So I took my truck to the shop I normally use (Four Oaks) as I needed to have my brakes done and don't want to go back to the original shop. They said that I still have the ignition module in the original spot but if there was a problem it would take much longer to restart on the few times it has stalled. They did say that my base idle was set too high and they readjusted it and think it is fixed.
On another note they told me the bolts to my rear drive shaft were loose and rattling. This really pisses me off. The first shop did my 60k service and had the truck in three times for a total of at least a week and drove it for 50 miles and never said anything about it. I noticed the rattle when I picked it up but was sick of going back.
OK rant over.
Old February 3rd, 2010, 04:58 PM
phoenix37's Avatar
phoenix37
john
I think this time your rant is justified. Cleary they should of been able to diagnosis this stuff at Ye Old Rover Shoppe #1
Old February 3rd, 2010, 05:16 PM
bjf's Avatar
bjf
barry f
94 ST #395
Yeah clearly just because every employee is from England does not mean they know anything extra. Last time I pay extra for an accent, unless of course we are talking about hookers. Well I did get f*cked
------ Follow up post added February 3rd, 2010 02:30 PM ------
So the shop just called. Truck is ready but my idle is still a bit strange to me. Stops at 1000 and after 3 or 4 seconds goes to 800. They say it is normal but I swear my truck didn't do it before that. They said it is nothing but I do wonder if a new stepper or different ECU would do anything.
Old February 3rd, 2010, 05:45 PM
phoenix37's Avatar
phoenix37
john
Wait you got your truck already?! Now Im going to rant. Theyve had mine for almost a week and you just dropped yours off last night! How does that work?! Please tell me mine is at least on a lift when you went.
Old February 3rd, 2010, 06:12 PM
Sorry John, you are not on the VIP list like Barry
Old February 3rd, 2010, 06:18 PM
phoenix37's Avatar
phoenix37
john
Clearly.. I think he bribed them with a visit from his alter ego Sandy.
Old February 3rd, 2010, 06:51 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Give it a few days, see if it calms down.
My oil line fix
My 100k stopped odometer fix
Old February 3rd, 2010, 07:07 PM
bjf's Avatar
bjf
barry f
94 ST #395
Got the truck and it idles fine. Stopping at 1000 isnt noticeable like stopping at 1200 to 1300. It drives much better.
John stop crying, your shit box is on the rack.
Old February 3rd, 2010, 07:27 PM
phoenix37's Avatar
phoenix37
john
you got me im the cry baby on the forum... so sorry your truck isnt idling perfectly..
Old February 3rd, 2010, 07:33 PM
bjf's Avatar
bjf
barry f
94 ST #395
ha it drives well now that the rear drive shaft bolts are tight.
I saw Larry packing your new transfer case with sand. Is that normal?
Old February 3rd, 2010, 07:36 PM
phoenix37's Avatar
phoenix37
john
it is normal considering my luck with tcases. Im going to start stockpiling them.
Old February 3rd, 2010, 07:47 PM
bjf's Avatar
bjf
barry f
94 ST #395
Yeah we might have to get a storage locker in LA for this crap
ac, distributor
TORX Vacum Advance rover4x4 Defender Technical Discussions 3 June 18th, 2009 09:06 PM
vacum advance rover4x4 Defender Technical Discussions 1 June 2nd, 2009 08:08 AM
vacum advance hoses rover4x4 Defender Technical Discussions 0 November 17th, 2007 12:12 PM
Vacuum Advance Andrew Vick Defender Technical Discussions 11 April 27th, 2007 08:25 AM
Vacuum Advance CGunther Defender Technical Discussions 0 September 28th, 2006 12:52 PM
