Distributor Vacum Advance - Page 2 - Defender Source
Old January 16th, 2010, 02:19 AM
bjf's Avatar
bjf
barry f
94 ST #395
So pissed. My car is doing the drop to zero RPM again!!!!!! Actually stalled tonight!
Old January 16th, 2010, 10:35 PM
PMKColorado's Avatar
PMKColorado
Paul Koentges
'95 White D-90, #2625
stall
You may have two seperate issues...Try pressing your enertia switch to determine if it is partially set. I have had the similar problem; diagnosed at dealer as bad fuel relay, then fuel pump, then after market alarm...all of which were replaced or removed. I found out while driving that by resetting the enrtia switch problem went away. It still happens sometimes...will eventually replace or bypass.
Old January 17th, 2010, 01:32 AM
bjf's Avatar
bjf
barry f
94 ST #395
where is this switch?
Old January 17th, 2010, 08:59 AM
I think its on the firewall near the air filter canister at least on my 95 it is. I read somewhere that disconnecting the diagnostic display can help things IDK I will see if I cant find where I read it for the details.
------ Follow up post added January 17th, 2010 09:01 AM ------
Has the module on the dizzy been relocated?
Old January 17th, 2010, 12:24 PM
bjf's Avatar
bjf
barry f
94 ST #395
what does it look like?
Old January 17th, 2010, 02:36 PM
bjf's Avatar
bjf
barry f
94 ST #395
thanks will do
Old January 17th, 2010, 03:19 PM
I think he is talking about the emissions service engine light. I am talking about the OBDI I code display.
Old January 18th, 2010, 10:01 PM
bjf's Avatar
bjf
barry f
94 ST #395
Truck is back at the shop. Claim it isn't the inertia switch or alternator. Maybe stepper but ussually when they fail they don't work at all but who knows.
Old January 18th, 2010, 10:45 PM
huck1974's Avatar
huck1974
shane cates
94 d90
mine did that about a year ago for a month. I made an effort to put decent gas in it for a while and it went away and never came back. Coincidence most likely.
Originally Posted by bjf View Post
For the last year, my 90 has had an intermittent problem where after driving for a bit it the RPM drop to just about zero and then jump back up. It wants to stall but doesn't. Happens at traffic lights and other times. I thought it was the stepper motor or the throttle housing being dirty but it kept coming back. Well a local shop said my distributor vacuum advance unit had a split diaphragm. They replaced it and set the base idle.
My question is now when I drive and I pull up to a light or come to a stop the RPM are about 1200 for a few seconds before it drops to just under 1000. Is this normal? I don't remember it this way. I am not sure if it seems weird because the borla is so loud or because I have been driving the 110 for a long time which idles differently. I trust the shop I just don't know.
thoughts?
And hay
And I love you too
Old January 22nd, 2010, 03:23 PM
bjf's Avatar
bjf
barry f
94 ST #395
Follow Up:
When I brought the truck back the first time for the weird almost stalling, they told me the stepper motor was missing the fiber washer. I knew it was as I had taken the stepper out at some point to clean it and the washer basically turned to dust. They put a new one on it and ever since I was having the stepped RPM drop that was driving me nuts. Today the shop admitted the washer was too big and causing the issue. As far as the stalling, an adjustment to my altenator cap seems to have fixed it.
I really hope this fix lasts.
Old January 22nd, 2010, 03:44 PM
alternator cap?
Old January 22nd, 2010, 03:58 PM
bjf's Avatar
bjf
barry f
94 ST #395
sorry meant distributor
Old January 22nd, 2010, 09:41 PM
Adjusted the distributor cap? What color is it?
Old January 22nd, 2010, 09:51 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Sounds like possibly a timing adjustment was done?
My oil line fix
My 100k stopped odometer fix
Old January 23rd, 2010, 11:59 AM
bjf's Avatar
bjf
barry f
94 ST #395
Not a 100% sure what was done. I picked the truck up and it is running correctly again thankfully.
Old January 28th, 2010, 04:23 PM
bjf's Avatar
bjf
barry f
94 ST #395
Reviving my thread. I have driven my 90 75 miles since the repair. Was running totally fine until today. Pull up to a light, truck stalls and won't turn over. I sit there with every asshole behind me beeping. Finally restarts and promptly dies. This happens a few time until finally it runs but idled high for rest of trip. Went out again and it si running fine.
WTF
Old January 28th, 2010, 04:35 PM
Start replacing stuff.
Does it do it when hot or cold?
Old January 28th, 2010, 04:48 PM
bjf's Avatar
bjf
barry f
94 ST #395
hot out today. ran fine in the rain last week. What should I start with?
------ Follow up post added January 28th, 2010 02:08 PM ------
From the shop
Barry
Im sorry you are still having trouble with your D90 , we checked everything out on your vehicle / distributor / / coil / fuel injection / fuel pressure / wiring connections / idle stepper motor / fuel fittings / engine e.c.u. etc etc totaling four hours in labor , it was then left idling for five hours one day & four hours the next ,it was then driven by the tech & me for a total of 45 miles , SO ,it was completly checked out + left idleing for a total of 9 hours . it was test driven 45 miles by my tech & myself & 75 miles by you ,before you had another problem ,I think I have done more than anyone would have to resolve this problem , that is obviously intermitent , I am probably upside down with this problem four or five hundred dollars ,so I am frustrated as well ,there is NO way I would have given your vehicle back if I thought it still had a problem , if you would like , I will drive it for a few days & see if it does it to me & try to get to the bottom of it .
Old January 28th, 2010, 05:10 PM
ignition module or did I miss that?
Old January 28th, 2010, 05:21 PM
bjf's Avatar
bjf
barry f
94 ST #395
I really don't know. This isn't something I know anything about.
ac, distributor
TORX Vacum Advance rover4x4 Defender Technical Discussions 3 June 18th, 2009 09:06 PM
vacum advance rover4x4 Defender Technical Discussions 1 June 2nd, 2009 08:08 AM
vacum advance hoses rover4x4 Defender Technical Discussions 0 November 17th, 2007 12:12 PM
Vacuum Advance Andrew Vick Defender Technical Discussions 11 April 27th, 2007 08:25 AM
Vacuum Advance CGunther Defender Technical Discussions 0 September 28th, 2006 12:52 PM
