Distributor seating - Defender Source
Old October 12th, 2016, 12:52 PM
bluewave
95
Distributor seating
Okay, I bought a distributor for the 3.9 V8 Defender 90 I have. I can't get it to seat down correctly in the notch. Basically, its not going "all the way in".
Being the genius (i am not), any help would be appreciated.
Old October 12th, 2016, 02:05 PM
Originally Posted by bluewave View Post
Okay, I bought a distributor for the 3.9 V8 Defender 90 I have. I can't get it to seat down correctly in the notch. Basically, its not going "all the way in". Being the genius (i am not), any help would be appreciated.
Are you sure. I seam to recall feeling the same when I was pulling mine in and out but it was actually in.
Old October 12th, 2016, 02:15 PM
bluewave
95
Yeah. Im 95 percent sure. i put some tack gasket on bottom of distributor and it kept showing up on the notch top. The oring also is only at the top and it appears i have room to push in more per original.
Old October 12th, 2016, 03:18 PM
Old October 12th, 2016, 04:02 PM
bluewave
95
did your oring sit high? mine seems to be sitting to high. not in...
Old October 17th, 2016, 08:27 PM
bluewave
95
got it. just rotated the crank pully a bit and it moved the gear and notch in place and the dizzy seats all way down.
distributor
Inner hub seal seating depth KevinNY Defender Technical Discussions 32 September 12th, 2009 02:05 AM
L5 S1 back problem - help for seating options needed paulb Misc. Chit-Chat 1 August 5th, 2007 03:52 PM
Child seating Daisy Defender Technical Discussions 38 October 26th, 2006 05:25 PM
Rear seating options in 110 gowyn Defender Technical Discussions 6 March 13th, 2005 01:04 PM
