Distributor Question - Defender Source
Old March 17th, 2011, 08:55 PM
usadventureracing's Avatar
usadventureracing
Brett
110
I went to replace the cap and rotor and the old rotor was a little tough to get out and when I replaced it with the new ones the cap does not seat all the way. The old cap and rotor do not seat all the way either, any suggestions on what happened? Thanks, Brett
1983 ROW D110
1970 Series III (Parting out)
Old March 18th, 2011, 08:56 AM
LRover's Avatar
LRover
J. Michael McCaig
If you pull too hard on the rotor while trying to remove it, the distributor shaft can become mis-aligned. If this is the case with your distributor, I am not sure what the remedy is other than rebuilding it. Maybe someone else here has figured out a quick fix. For future reference, it is better to take a chisel and break the old rotor to remove it than pull upwards with force.
Old March 18th, 2011, 01:31 PM
carlosz's Avatar
carlosz
Carlos
when you install the new rotor use a little dielectric grease to prevent future hang up.
Old March 18th, 2011, 02:05 PM
usadventureracing
Brett
110
Fix it, had to pull the distributor as the springs on the counter weights were off. Took it apart, installed and timed, she runs like a top now.
1983 ROW D110
distributor
