Distributor 1995 - Defender Source
Old August 15th, 2005, 01:28 PM
dbwitt's Avatar
dbwitt
Darrin Witt
1995 Defender 90
Distributor 1995
Hello,
Looking for a distributor for a 1995. I understand that they are difficult to get. Anyone ever find a non-LR distributor to fit? Does the Range Rover 95 fit? The dealership says that mine may be going. So I said thanks and drove away.
Old August 15th, 2005, 02:43 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Mallory and MSD both make models that work. Try talking with Sam at Century Performance. If you want a land rover one, I have one that I would make you a deal on (used, but works fine--I am running a Mallory).
Old August 15th, 2005, 03:09 PM
dbwitt's Avatar
dbwitt
Darrin Witt
1995 Defender 90
I think I am going to go with the Mallory Dist. Thanks.
Old August 15th, 2005, 05:31 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Accell has also come out recently with a Dual-Sync for the buick/rover, not sure of compatiblity or advantages yet. Mallory would be the easiest, as it can just drop in and mate up with the factory ECU and no extra boxes needed.
Chris... did they handle the gear changeover for you? or did you do that yourself? (Or did you even need it?)
Darrin. Do you have serpentine belts or V-belts on your engine?
-Hans
My oil line fix
My 100k stopped odometer fix
Old August 16th, 2005, 12:30 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I did it myself. I was told the hole was already in the shaft, but in reality, it was not. I had it drilled for the gear (they give directions with the distributor) and that was that.
Also, the Unilite/espark module replaces the ignition module altogether. Now, all I need to do is carry an extra e-spark module (it senses when the rotor passes and is $36 at summit). I have yet to replace it, though.
1995, 95, distributor
