Distributor - Defender Source
Old March 12th, 2009, 09:28 PM
Distributor
Any pointers on removal? I have an ignition module relocation kit I need to install.
Old March 13th, 2009, 03:41 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Agreed, don't remove it if you don't have to.
If you do have to remove it, you need to mark the direction the rotor is pointed and make sure the engine doesn't turn at all. When re-installing, make sure it's as close to that marked spot as possible, and hit it with a timing light.
-Hans
My oil line fix
My 100k stopped odometer fix
Old March 13th, 2009, 08:00 PM
How is the module attached to the distributor, it looks like it is held on with screws? I cant see how to get it off without removing the distributor, I really really dont want to have to remove it.
Old March 13th, 2009, 09:31 PM
Hans's Avatar
Hans
Hans Haase
Yep, just two screws holding it to the distributor. Comes off really easy. Pulling the distributor cap only will probably get you a good amount of room. Just mark the #1 plug, and have the firing order handy.
My oil line fix
Old March 26th, 2009, 08:24 PM
man it doesnt look like there is any way to get this thing out without removing the distributor.
distributor
Mallory Distributor, Coil, Magnecor Wires, ect. Paul Grant For Sale - Parts 0 November 15th, 2007 08:03 PM
Need a Distributor for a 1995 dbwitt Defender Technical Discussions 8 February 14th, 2006 10:43 AM
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
Distributor 1995 dbwitt Defender Technical Discussions 4 August 16th, 2005 12:30 AM
Rattle noise from distributor? hmmmm Davis Defender Technical Discussions 5 June 13th, 2005 10:39 AM
