Distributerless ignition conversion? - Page 2 - Defender Source
Old September 18th, 2007, 07:53 AM
themaxx's Avatar
themaxx
Ade
94 ST
Good info, thanks Dave.
Old September 18th, 2007, 10:27 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I like this guy's write-up for his Megasquirt installation:
http://www.finkbuilt.com/blog/megasquirt/
An interesting point is that he installed Megasquirt first to replace the distributor using EDIS, then later implemented the fuel injection portion of the system.
So, you could go EDIS to repalce your distributor and still run the Land Rover ECU...
Some quotes from the article re: ignition
Update: No ignition table tweaking needed. Tim’s advance map is fantastic. I had a slight mis-understanding about where to set the baseline timing for “limp home mode”. I essentially had the VR sensor 1 tooth off. To correct this in software, I set the “Trigger Offset” parameter in MegaTune to -10. At some point, I need to physically reposition the VR sensor so that “limp home” will be optimal. Once that confusion was cleared up, I was off to the races.
So how do I like it?
It’s amazing .
I knew that ignition timing was an important variable in engine performance, but I honestly didn’t expect this much improvement. The motor runs so smoothly throughout the RPM range, it just climbs and climbs. I can’t keep my foot out of it. Totally programmable, solid-state ignition with vacuum (MAP sensor) advance works really well.
Distributors are kind of garbage.
I can’t wait to install the fuel injection.
Old September 19th, 2007, 11:37 AM
themaxx's Avatar
themaxx
Ade
94 ST
It's surprising, I haven't found one single negative comment so far regarding it.
conversion
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
Mallory Conversion - Ignition Module? nimbusnic Defender Technical Discussions 5 December 29th, 2008 06:45 PM
Ignition? Trigger Defender Technical Discussions 12 August 1st, 2005 08:53 PM
different ignition options vesparover Defender Technical Discussions 5 December 5th, 2003 03:02 PM
