Distance beetween alternator mounting ears 300Tdi ? - Defender Source
Old February 25th, 2009, 07:28 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I know already that the distance beetween upper and lower
mounting points is 150 mm. What i'm missing is the distance
beetween both lower mounting points.
Anyone, before i take my alternator out just to check that ?
- Charles Eames
Old February 25th, 2009, 11:06 AM
I'll check tonight. I think they are 80mm wide mounts.
http://forums.lr4x4.com/index.php?sh...ode=linearplus
Old February 26th, 2009, 07:53 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Is it 84 mm by any chance ?
- Charles Eames
Old February 27th, 2009, 07:44 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
The 300 alternator only had 3 mounting points. So I'd not be sure what the other point would be measured against. The lower mount is on the front only and is on the same plain as the top mount.
Side note. You can use a discovery 4.0 alternator with 4 mounting points by modifying the ......errrr..... bit that the alternator mounts on, which my sleep deprived numb head is having trouble describing. Offer a V8 (serpentine) alt. up to the Tdi and it will become very obvious.
Matt Browne
Old February 28th, 2009, 10:52 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
My mistake.
One single mounting point bottom and
two on line mounting points on the upper part.
I checked distance and it's 84 mm.
- Charles Eames
300tdi, alternator, mount, tdi
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
300Tdi wings/ radiator finisher (defender) Lyman Wanted 2 March 8th, 2006 05:51 AM
94 D90 wagon, 300tdi for sale Chris Cox For Sale - Vehicles 20 November 9th, 2005 12:43 PM
1995 Discovery 300TDI, Trail Ready.... Joe B For Sale - Vehicles 1 June 23rd, 2004 06:26 PM
