Dist plug?! - Defender Source
Old September 30th, 2005, 05:38 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Dist plug?!
I am ready to start the 110 BUT I have a pair of male elec studs & a single stud on the dist. I don't remember what plugs into the single. The plugs are on the module.
Peter
Old October 1st, 2005, 10:21 AM
??? Do you mean on the coil? Or maybe the amplifier? Can you take a pic? I belive the only single male stud on the distributer goes to ground, the amp on mine is bolted to the distributer and from the amplifier 2 wires run to either side of the coil and 1 wire from the coil runs back to the ECU and the other to 12 volts here is an EFI diagram I hope it helps! I spent some time rewiring the engine on mine and it feels real good once it starts
ID:	3958   Click image for larger version
Old October 1st, 2005, 11:59 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Thanks Mike I just can't find the wire??
Name:	110 resto.jpg
Old October 1st, 2005, 02:30 PM
Yep thats the ground lug! Mine has this dinky little black wire that ran to the bottom of the block.
Old October 1st, 2005, 04:58 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Check the front drivers side of the block for the dinky black wire Mike is talking about--it will be rather low but not all the way down. It can sometimes fall behind the power steering pump bracket.
Old October 1st, 2005, 07:29 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Thanks to all! I found it after I sent the pic's! I had a major brain cramp! She will be ALIVE tonight!!!
OBD Plug no power??? Cyborg Defender Technical Discussions 4 December 29th, 2005 11:29 PM
what does this plug in to? mattdh Defender Technical Discussions 6 November 2nd, 2004 11:59 PM
What does this plug go to??? Chris Cox Defender Technical Discussions 1 July 11th, 2004 03:24 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
Serial Link Mating Plug? Ramsay Defender Technical Discussions 9 May 13th, 2004 11:27 PM
