Discovery I drop arm on D90 box?? - Defender Source
Old March 20th, 2009, 12:05 AM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Will the Discovery I drop arm fit the D90 steering box, ie are the splines the same?
I already know the drop arm does not have a ball joint (that's the point).
Has anyone made this mod??
Seems that even though the arm is shaped differently and is "higher".....the ability to use a TRE should allow it to still be used.
Old March 20th, 2009, 12:11 AM
Not a real problem. The disco arm has slightly less drop even with the bottom mount TRE (ball joint in Land Rover speak). If you do make the change, I am interested in your take off arm and the cross tube. I would even trade you for the disco stuff. I should add that you would want the disco tie rod as well (it is where the damper mounts on a disco).
Most people go the other way because the damper on a disco is vunerable off-road to damage.
90, cover, d90, disco, discovery
steering drop arm ball joint souza Defender Technical Discussions 20 February 29th, 2008 11:41 AM
New In Box D90 Radiator Leftover Parts willtillery For Sale - Parts 0 February 15th, 2006 11:15 AM
Drop arm! TwisteD90 Defender Technical Discussions 9 July 19th, 2005 09:27 PM
Steering drop arm kellymoe Defender Technical Discussions 12 November 7th, 2004 02:07 PM
D90 fiberglass hardtop, new in box Chris Cox For Sale - Parts 0 November 6th, 2003 08:13 PM
