Discovery 200tdi injector pump return line - Defender Source
Old October 2nd, 2016, 07:13 PM
richord
Richard Ordowich
1987/D90
I replaced my 2.5TD with a Discovey 200tdi.
There is a return line on the back of injector fuel pump that has banjo connection with one side connected to the injector spill rail. Where does this the other pipe connect to? The fuel tank return?
"Slow down and smell the diesel"
Old October 2nd, 2016, 07:15 PM
Fuel tank return. You should have a line already there from your last motor.
Old October 2nd, 2016, 07:17 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Two plumbing options - plumb the return to the filter or directly back to the tank
Old October 3rd, 2016, 06:03 PM
richord
Richard Ordowich
1987/D90
Is there any advantage returning to the filter versus directly back to the tank?
Old October 3rd, 2016, 06:16 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
back to the tank, about a 1/2 of the the fuel pumped is used for cooling the injection pump, also if there is any air in the system t gets released in the tank, where if it's plumbed to the filter as in the good old days, you just get air pumped back to the pump. Make sense?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
200tdi, cover, disco, discovery, tdi
200Tdi Discovery injector pump to fuel filter pipe part number richord Defender Technical Discussions 5 July 26th, 2016 06:13 AM
200Tdi Fuel Return Line Help LostChord Defender Technical Discussions 11 February 22nd, 2016 07:57 PM
200TDI injector/fuel pump johnnyb77 Wanted 2 June 16th, 2014 04:47 PM
Injector return line leak no more BlackField Defender Technical Discussions 0 August 24th, 2013 10:48 PM
200Tdi injection fuel return line banjo bolt Apocalypse Vehicle Defender Technical Discussions 8 August 20th, 2013 10:13 AM
