Discovery 200TDI Fuel line Part Numbers - Defender Source
Join the Defender Source Community Today
Old July 24th, 2016, 06:53 AM
richord
Richard Ordowich
1987/D90
Replacing my 2.5TD with Discovery 200TDI in my Defender 90.
I need the part numbers for the following fuel lines including banjo bolts:
1. Injector pump
2. Lift pump
Where can I find the part numbers and preferably a parts diagram for these?
"Slow down and smell the diesel"
Old July 24th, 2016, 07:24 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Why don't you just use proper fuel line clamped to the fittings instead of the nylon line that will kink, split, and leak air in and fuel out?
RDavisinVA
Old July 24th, 2016, 08:08 AM
Robert, I need to run some fuel lines too. What type of fuel line do you recommend?
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old July 24th, 2016, 01:35 PM
richord
Richard Ordowich
1987/D90
Robert., I don't have any of the original fittings for the Discovery 200TDI. They were not on the engine when I got it. That's why I need the part numbers.
Old July 24th, 2016, 02:29 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1986 Tithonus LHD
Richard,
I don't think there were any banjo bolts on those fittings. They are simply threaded fittings with steel pipe ends that the fuel line clamps on to. Any fuel line will do. Go with Viton or something similar if you want the best, otherwise, go down to Napa or Autozone.
For the fittings, start here:
Lrcat
Should look something like the threaded piece in the picture. This is part no ESR 267. This is what I found in 5 minutes. You can probably find the exact pieces with a little more searching. IIRC, the 2.5NA fittings moved right over to the 200TDi. Do you have your old engine still?
Old July 24th, 2016, 07:51 PM
richord
Richard Ordowich
1987/D90
Neil, thanks the banjo bolt is needed at the injector fuel pump end. I still have the 2.5TD engine in the truck so it looks like the remaining fittings will work.
I moved my alternator to the right side of the right side using a dual alternator lit. This gets it out of the way from all the turbo pipes. Almost ready to do the swap.
Richard
tdi, 200tdi, cover, discovery, disco, part, fuel
Discovery series 1 extended brake lines crown14 For Sale - Parts 1 September 29th, 2015 08:03 PM
Spill Return Lines - 200TDI javelinadave Defender Technical Discussions 17 April 10th, 2014 02:24 PM
No fuel to motor after new fuel lines-help Tyler Wirken Defender Technical Discussions 7 April 22nd, 2012 02:31 PM
200tdi oil cooler lines cabell For Sale - Parts 3 June 18th, 2009 11:24 AM
200tdi oil cooler lines tomaco1 Defender Technical Discussions 3 February 7th, 2009 07:50 AM
