Discovery 1 rear axle into Defender questions - Defender Source
Old February 28th, 2014, 08:51 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
I spent the last half hour searching, to no avail...
-D1 axle has a 3-hole drive shaft, whereas my Defender has a 4-hole. Options? (I saw a link to a solution thread on Discoweb but can't find it)
-D1 axle has 2 brake lines, Defender has one. Just swap the Defender T-part in?
-What brake fluid does the defender use?
Thanks in advance,
Paul.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old February 28th, 2014, 09:00 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
You can swap the 3 hole flange for the 4 hole. You have to remove the big nut in the center them use a puller of some kind to get it off.
Just swap in the T off your existing axle for the brake lines.
Old February 28th, 2014, 09:27 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
There is no nut on the Discovery 1 three hole flange. Is it inside the diff?
Old February 28th, 2014, 09:36 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
There must be! It has to be held on some way.
Old February 28th, 2014, 09:47 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
This is what the end looks like...
Old February 28th, 2014, 09:50 PM
There is a Land Rover special tool for removing that piece. I'm sure there is a thread somewhere on how to remove it without a special tool. I suppose a slide hammer would work. There is a bolt under it with a 15mm bolt head IIRC.
Old February 28th, 2014, 09:53 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
I just scraped all the crud off, and didn't see any pin, bolt or other fixture that holds it on.
I am sure I saw a thread on Discoweb about how to make a 4-hole fit a 3-hole. Sound familiar?
Edit: How about using the diff from my current axle? Would it fit?
Old February 28th, 2014, 09:55 PM
Here you go:
http://www.discoweb.org/rotoconversion.htm
Old February 28th, 2014, 10:10 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
or just swap the diff over
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 28th, 2014, 10:17 PM
What axle is in your current setup?
If you use a slide hammer with a stud threaded into the peg, it should come right out. I was thinking of a DII that has the 15mm bolt. A D1 diff would have the large nut.
Old February 28th, 2014, 10:21 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Current is whatever was stock in 1985.
Do I understand correctly that a slide hammer will remove the 3- hole part, then I can pound the 4-hole part on in its place?
Old February 28th, 2014, 10:27 PM
robertf
Robert F
1995 Discovery
No way a slide hammer gets that thing out.
The first time I converted one I used sockets and a bolt to assemble a puller. The I.D. of the nipple is threaded.
The most recent one I removed the diff, threw it in the trash, and then put a disco front diff in its place.
Old February 28th, 2014, 10:30 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Paul, you will need a new yoke ands spacer for the disco axle. The your current yoke and pinion is the old style coarse (4) spline, while the disco pinion is the newer fine spline.
-Jeff
Damn it, I thought this would be straight forward. Any idea on part numbers?
Sounds like the best solution here is going to be keeping my '85 diff?
Old February 28th, 2014, 10:34 PM
jafir's Avatar
jafir
Jafir Elkurd
Ashcroft says they redrill the hole for a larger bolt before attempting pulling that pin.
My D1 axle came out of a 1999. I think 97+ (or is it 98?) they switched back to a 4 bolt flange.
Old February 28th, 2014, 10:38 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Originally Posted by javelinadave View Post
Awesome! This is exactly what I was looking for.
Yes. the discoweb link that Dave posted is a good step by step. you can see that the snout is internaly threaded for a bolt to be used with slide hammer. I have heard it can me VERY tight. As i mentioned you will need the yoke and spacer as well. John Gadd (roverdude) might have it.
-Jeff
Thanks Jeff! I PM'd RoverDude.
Old February 28th, 2014, 10:54 PM
Paul, probably the third time I have told you this, but KEEP the 85 diff! It should be a 24 spline four pin (ie much stronger) carrier. If it is 10 spline, then swap the pinion as described above. The diff swap is easy. Just pull the axle shafts and unbolt the diff.
Old February 28th, 2014, 11:18 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Okay, I'll disassemble both & compare, then do as prescribed. How likely is it to be a ten spline? I seem to remember they mixed it up pretty well?
Another thought- should I replace any of the A-frame stuff on top of the diff? I have read that the parts can wear, causing clunking.
Old February 28th, 2014, 11:33 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Dont dissasemble. On your existing axle, pull the short side shaft. if its 24 spline, then procede with the diff swap. If its 10 spline, then swap the yoke on the Disco axle.
-Jeff
Will do!
I will also be installing some Dynamat this weekend...
Old February 28th, 2014, 11:36 PM
Anything is possible, but my understanding is rear diffs in early V8 90s were the 4 pin 24 spline. The a frame ball joint is something I would consider replacing it it looks at all worn. Check bushings too, but if they all good and feel good, I would just run them.
Old February 28th, 2014, 11:53 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Fingers crossed!
Ok. The brake discs & pads on the donor axle look good. I will swap the diff oil no matter what.
axle, cover, defender, disco, discovery
Whats in my container??????? SafariHP The Vendors Loft 30 November 26th, 2015 07:31 AM
Modified 1995 Defender 90 jdb3760 For Sale - Vehicles 23 April 21st, 2009 09:40 PM
Defender 90 soft top rear door crobinson For Sale - Parts 1 November 17th, 2005 01:04 PM
Salisbury Rear Axle for Sale Northface For Sale - Parts 1 August 12th, 2005 06:54 PM
Dumb questions to ask when looking at a defender... Grouchie@irdumb.co Defender Technical Discussions 2 July 6th, 2005 11:31 AM
