Discovery 1 rear axle into Defender questions - Page 3 - Defender Source
Old March 8th, 2014, 09:23 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Update
Update:
Diffs swapped over, brake line 'T' removed from old axle, new brake line from body to axle installed, joint between axle & diff case sealed, axle shafts back in, 4-hole thingy reinstalled & cotter pin inserted, ready to go under the rig!
I'll post an update tomorrow, hopefully when the job is complete.
Paul.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old March 9th, 2014, 07:01 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Done. What a pain in the a$$! Hardest parts were 1) getting everything aligned to attach the new axle and 2) getting the bleed nipples to break loose so I could bleed the system.
Pile of old stuff (Note rusted through shock covers)
The biggest difference is that the rear wheels now sit about 1.5" inboard. That should mean less crap gets thrown up the side of the rig!
I also fitted a front license plate, as I really don't want a ticket.
Next project- new front axle (used setup from a RHD 110) and black fender flares.
Note: I will have a set of four 1.5" Aluminium spacers for sale after I install the front axle.
Thanks for all the help!
Paul.
Old March 9th, 2014, 07:07 PM
Well done.
Is the width reduction due to no longer needing spacers in the rear after putting in the disco axle?
Originally Posted by pendy
I'm here for the D's
Old March 9th, 2014, 07:11 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Originally Posted by cgalpin View Post
Well done.
Pretty sure that's the case. I measured both axles & it looked like the wheels would sit the same distance apart- except of course the Freestyles wouldn't fit over the hubs on the drum braked axle.
Old March 9th, 2014, 08:01 PM
why transplant in a 110 front axle ?
Old March 9th, 2014, 08:27 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Doug:
The axle that is on there is shot (lots of rust, pitted balls, nasty noise & lots of slack in the diff, leaking oil, joints badly worn, pads badly worn, discs scored, etc. etc.).
So after some discussion in this post;
http://www.defendersource.com/forum/...ad.php?t=51706
I was going to refurb mine. But I wanted to get away from having to use spacers, so when a '96 RHD Defender axle came up, I bought it.
Cheers,
Paul.
Old March 9th, 2014, 08:37 PM
Nice work Paul! I did not even get a cell phone call.
IMHO it looks much better without the spacers.
PS on the new disco axle, make sure the breather is cleaned out so it does not pressurize the axle and cause a leak. Undo the nut, clean it out, and blow through the line to make sure it is clear.
Old March 17th, 2014, 10:25 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Good call Ron! Axle breather was completely plugged!
Old March 18th, 2014, 01:04 AM
That is what I am here for!
axle, cover, defender, disco, discovery
Whats in my container??????? SafariHP The Vendors Loft 30 November 26th, 2015 07:31 AM
Modified 1995 Defender 90 jdb3760 For Sale - Vehicles 23 April 21st, 2009 09:40 PM
Defender 90 soft top rear door crobinson For Sale - Parts 1 November 17th, 2005 01:04 PM
Salisbury Rear Axle for Sale Northface For Sale - Parts 1 August 12th, 2005 06:54 PM
Dumb questions to ask when looking at a defender... Grouchie@irdumb.co Defender Technical Discussions 2 July 6th, 2005 11:31 AM
