DiscoII front drive shaft - Defender Source
Old September 1st, 2006, 10:48 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Has anyone here used the DiscoII front drive shaft before? I think the only mod you have to make is the output flange from the tranfer box to that of the DiscoII. I picked one up that needs a little TLC from ebay and will probably throw it on when I do my springs but I am curious if anyone here has already had experience with it...
Old September 1st, 2006, 10:56 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
I've used one (on a DI) but instead of using the flange off the DII I purchased an adapter from Toddco. Since I have a lift I thought it would be better to add an inch to the shaft. Right now I removed it and installed a 30 degree DC wide yoke shaft.
Name:	D2 Driveshaft & spacer 1.jpg
ID:	6477   Click image for larger version
Name:	D2 Driveshaft & spacer 2.jpg
Name:	D2 Driveshaft & spacer 3.jpg
ID:	6479   Click image for larger version
Name:	D2 Driveshaft & spacer 4.jpg
Name:	D2 Driveshaft & spacer 5.jpg
ID:	6481   Click image for larger version
Name:	D2 Driveshaft & spacer 6.jpg
John C.
Old September 1st, 2006, 02:34 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Thanks, John. Was there a reason you switched shafts such as vibration or anything? Just curious. Thanks for the pics, too!
Old September 1st, 2006, 04:00 PM
JohnC
I installed the DII shaft because of vibes from a 2 lift. When I went up to 3 inches the DII shaft was cutting it so that's when I decided to install one of our driveshafts.
John C.
Old September 1st, 2006, 07:29 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Will the DII shaft bolt directly onto the LT-230? I need one from the rear of my series project... John, let me know if you want to sell it
Legend in My Own Mind.
disco
Help! Question about front rotor and drive shaft. DesertRat Defender Technical Discussions 5 October 24th, 2005 07:14 AM
Rovertracks HD front axles CV's & GBR drive flanges ToaDisco For Sale - Parts 8 July 4th, 2005 01:50 PM
D11 front drive shaft jorge Defender Technical Discussions 3 April 12th, 2005 08:03 AM
front drive shaft jorge Defender Technical Discussions 6 December 9th, 2003 11:23 AM
» Defender Registry
Rover
mjekogian
90 V8
KeithD
Add your Defender
