Disco II Parking Brake Circuit - Defender Source
Old February 24th, 2011, 04:51 PM
aosias's Avatar
aosias
Alexandra
1995 D90
I have a new DVD deck to install in my 03 Disco. Need to connect a wire to the parking brake so that when the vehicle is stopped and the brake is activated my DVD will work. Not sure how to run the wire and where I need to tie in.
Posted on Dweb and haven't had any help over there. Thought someone here mught be able to explain it.
Next I will cry about how to connect my universal steering wheel control thing.
Alex
Old February 24th, 2011, 05:46 PM
PaulMc's Avatar
PaulMc
Paul McConnell
1989 110 2.5 Turbo-Diesel
Alex
I've cropped the wiring diagram to show just the relevant parts -
Name:	LHD Brake Warning Light.jpg
The wires are commoned at Header C0293 (pins 1 to 4) -
Name:	C0293 LHD Header.jpg
Paul.
1989 Arles Blue 2.5TD 110 Hardtop
1999 Epsom Green Discovery II 4.0 V8i 'XS'
Old February 24th, 2011, 07:12 PM
Do you really want to do this? Most people try to bypass this sort of functionality.
Originally Posted by pendy
I'm here for the D's
Old February 24th, 2011, 07:31 PM
By pass it...
Old February 24th, 2011, 07:36 PM
The Dro
Dro
1988 Ninety
x2.
Be careful how you do this... You need to find out if the system either needs a Voltage applied to it or needs to be grounded to complete the circuit.
Most electrical component on vehicles are hot all the time.
Old February 24th, 2011, 07:57 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Bypass works for me. Just need it connected to something so it will work. So should I tie it into the red or the yellow wire and then use the ground? Currently trying to figure out how to snake my iPod cable from the back of the stereo to the glove box and how to run the GPS antenna. Tempted to put this fnacy unit inthe 110 just because it would be easier to install and run all these cables.
Of course it's almost dark now, all my tools (including flashlights) are in boxes since we are moving and I need to use the truck tomorrow to drive to Denver. So much for a quick swap.
Old February 24th, 2011, 08:49 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
The PAC TR-7 is the unit you want.
It is a bypass box that will control all those functions. Simple hook up. We use them in all the in dash DVD players we install.
Email:
Old February 24th, 2011, 09:36 PM
The Dro
Dro
1988 Ninety
No, you will burn the unit if you cross the cables... yellow/red are 12v and they don't play well with the ground cable.
I can only assume that when the brake is pressed it will go to ground.
Do you have the schematics of the unit? or model?
Old February 24th, 2011, 09:57 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Thanks Mike. Guess you got scared when I threatened to install it in the 110
Old February 25th, 2011, 07:42 AM
ECR's Avatar
ECR
No, not scared.
Its just that bypassing some of those units is easy and some it is not so easy. The lower end ones you can sometimes just ground or power the "safety" wire. On some units they need a combo of signals done at certain times, so just giving them power or ground will not do the trick. The Alpine units for example require the little computer box, you can't trick them easily. It really depends on the unit and how it is built.
Email:
brake, disco, disco ii
Parking Brake Abrooks Defender Technical Discussions 15 September 23rd, 2011 09:57 PM
Parking brake retrofit advice Abrooks Defender Technical Discussions 5 April 13th, 2009 11:39 PM
Parking brake circuit flynn23 Defender Technical Discussions 1 November 29th, 2008 07:28 AM
parking brake switch Campbell Defender Technical Discussions 6 September 20th, 2005 08:45 PM
Parking brake light howellm70 Defender Technical Discussions 4 September 27th, 2004 02:19 PM
