Disco headlight dim - Defender Source
Old July 6th, 2017, 04:07 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Disco headlight dim
One headlight on my D1 is way dim, and I think it is a ground issue although I cannot find the location for the headlight ground. Thought it was the actual connector, cleaned, tightened, and adjusted but not one bit of light output increase or flicker from halogen bulb.
Wiring from lights enter loom and travel back into bigger loom headed to the bulkhead. If I had a damn lift I might have better luck, but doing the sanford and son garage skills I am trying to locate the right ground location for the headlights. Anyone know?
Wires at connector appear fine, no burn marks, wire & connector look completely fine. Other headlight works great, no issue.
1973 Series 3
1991 Range Rover Classic
1994 Defender 90
2006 LR3 SE
instagram.com/ridgerovers
Old July 6th, 2017, 04:54 PM
Chris B
72 + D1 drivetrain =?
Swap bulbs side to side.
Old July 7th, 2017, 08:13 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Found crap ground. Cleaned up and repositioned and all is well. Went ahead and cleaned other grounds while at it.
1973 Series 3
1994 Defender 90
2006 LR3 SE
Old July 8th, 2017, 07:49 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
We had to do this on my kid's D1 twice. Second time around I filled the headlight connection with dialectic grease. One year or so out and still doing well. Had to do the same with the brake switch and the gear select wiring. He got stuck out without being able to get out of park. This is all on a cherry D1. Time kills electronics.
disco, ht
Disco 1 headlight switch (no dash or tail/running lights) hillstrubl Wanted 6 February 10th, 2014 08:49 PM
Dim headlight (REALLY dim) GuamPilot Defender Technical Discussions 4 July 24th, 2013 01:05 PM
Rovers North Front Headlight Guards $180 Wolf Fabrication For Sale - Parts 2 November 2nd, 2011 07:41 PM
D-90 1994 parts and Disco 2 parts JAD For Sale - Parts 10 August 1st, 2006 02:00 PM
Help empty my garage! Ton's of parts.. RedRhinoProducts For Sale - Parts 12 June 1st, 2005 08:24 AM
» Defender Registry
Defender 90
brud
Max
juddy
Add your Defender
