Disco disc brakes on Salisbury rear end - Defender Source
Old November 16th, 2010, 02:31 PM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
Anyone ever fit Disco disc brakes on a Defender Salisbury rear end ? (as to why, first they are more effective at stopping, 2nd they are cheaper in the US,) I'd hate have to replace the whole rear end with a Disco rear end, because I like the added strength of the Salisbury
Chris "V"
Old November 16th, 2010, 02:34 PM
The disco calipers are smaller pistons that the proper 110 ones, but yes, I bought all the parts to convert my sals to a disco I disc brake set up. I have not installed them yet, but other than buying the caliper brackets and new inner axles and used 24 spline thin flanges, you can use everything on a disco I rear axle to convert a sals. It ended up being pretty expensive in parts caliper brackets are $100 each and you need two, inner axles were on special for $125 each and the flanges were from will tillary and I think he just threw them in with an order because I am a nice guy, but probably would have cost $20 for the pair.
All in you are looking at $500 before you buy rotors or calipers. I happened to have both new sitting on the shelf so ....
Old November 16th, 2010, 02:42 PM
dchapman
Daniel Chapman
1999 D1
There are a couple rite ups on converting a drum Sals to disc. You'll want to stick to the non ABS RRC hubs/spindles as they work with the factory axle shafts.
The only thing different between Disco and earlier RRC is that the Disco calipers use metric mounting bolts rather than SAE. If you go with older (non NAS) RRC calipers, they dont have metric plumbing.
-Jeff
This is what we did. And I think the caliper brackets were only $100 for the set, and not $100ea, from Rovertracks.
Old November 16th, 2010, 02:45 PM
Chris Velardi
Chris Velardi
1975 101FC
Anyone know the locations of the write-ups ?
Chris "V"
Old November 16th, 2010, 02:46 PM
The prices on the brackets have jumped. Best price is $100 each from RN or RDS. If you use the old non-abs rrc hubs, two isses are present. One, alloys don't fit over the big flanges and, two, you have to mill the brackets slightly. I was not happy about those two things so I bought the inner axles and the ABS hub stuff.
------ Follow up post added November 16th, 2010 02:47 PM ------
http://www.defendersource.com/forum/...ury+disc+brake
Old November 16th, 2010, 02:48 PM
dchapman
Daniel Chapman
1999 D1
I think you need to revisit this mod. Your information is not correct.
Old November 16th, 2010, 02:53 PM
What is incorrect Dan? I got my info from Keith at Rovertracks and Les at RN.
PS when I say the alloys don't fit, they do bolt on but the flanges stick through the center and you can't run a center cap.
Old November 16th, 2010, 02:58 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
caliper brackets can be had for about $150.00 for the pair from any of the UK parts suppliers (lr series, craddocks) with shipping...
Here's a link to a write up on it:
http://forums.lr4x4.com/index.php?showtopic=11685
Milling the brackets will cost about $20
Old November 16th, 2010, 03:09 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
these guys are fairly nice to deal with
http://www.zeus.uk.com/land-rover.php
Old November 16th, 2010, 03:54 PM
dchapman
Daniel Chapman
1999 D1
Lucky8 has the FTC3306 brackets for $70ea. Took 5-minutes to find that price only sending one text message. PT or Tillery may be cheaper, I don't know, but I bet even that price could be beat.
Alloys will fit.
Old November 16th, 2010, 04:07 PM
They are discussing how to do this economically Tom. Nothing Zeus sells is cheap.
brake, disco, rear end
Rear disc brake options kellymoe Defender Technical Discussions 44 April 9th, 2008 09:34 AM
Salisbury Rear Axle for Sale Northface For Sale - Parts 1 August 12th, 2005 06:54 PM
Help empty my garage! Ton's of parts.. RedRhinoProducts For Sale - Parts 12 June 1st, 2005 09:24 AM
