Disco axles on a 110 - Defender Source
Old October 19th, 2010, 01:12 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
A couple of Disco Axle questions.
Can I put a disco axle on my 110 and swap the calipers and rotors from the 1983 RHD 110?
And it may be blasphemy! But what about putting a Disco axle on the rear in place of the Salisbury?
For on road drive-ability.
Old October 20th, 2010, 12:10 PM
1. Why would you want to use those calipers and rotors? They are basically the same (other than the threads) as a disco I.
2. Sure you can use a rover axle in the rear. You need a new longer rear driveshaft and to redrill the spring plates on the axle to move them over to run the 110 diameter springs.
Old October 22nd, 2010, 11:22 PM
berti1554
Robert Klima
84/110
But the Disco Rover-axle has less gross axle weight rating than the Salisbury rear axle or the P38 rear rover axle used on 110/130's from my '02 onwards
110, axle, disco
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
Disco 3.9 into 110 Jimbo Defender Technical Discussions 6 August 19th, 2005 03:29 PM
Help empty my garage! Ton's of parts.. RedRhinoProducts For Sale - Parts 12 June 1st, 2005 09:24 AM
