Disco 200tdi rebuild for a Defender? - Defender Source
Old October 4th, 2013, 11:54 AM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
I've got a 200tdi disco engine that I'm rebuilding for my 90. I'm trying to decide if I should use a defender 200tdi turbo assembly or a 300tdi turbo assembly. I also need to decide if I should use the disco timing case or a defender timing case.
I have a 200tdi RRC so I'm temped to use the disco timing case so that I have more parts in common between the two trucks but I'm not sure if the defender turbo will work out with the disco timing case.
Any thoughts?
Old October 4th, 2013, 12:42 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
I have a 200tdi with a disco timing case and a defender 200tdi turbo manifold. It works without issues. However, my alternator has been relocated to the left of the thermostat (when looking at the engine from the front). I'm pretty sure the alternator would be in the way of the intake manifold runner if it wasn't relocated.
Old October 5th, 2013, 12:26 PM
headdamage's Avatar
headdamage
Andrew
Good to know, I suspected that the alt might need to change sides with the disco front and defender turbo.
200tdi, defender, disco, rebuild, tdi
Disco R380 ready for rebuild galen216 For Sale - Parts 1 September 17th, 2013 09:17 AM
Disco and the 200tdi swap Stork17 Defender Technical Discussions 13 December 1st, 2008 08:30 PM
D-90 1994 parts and Disco 2 parts JAD For Sale - Parts 10 August 1st, 2006 03:00 PM
DEFENDER and DISCO I PARTS ember For Sale - Parts 6 August 5th, 2004 11:35 PM
1997 Disco axle shafts in my 1995 Defender? MonLand Defender Technical Discussions 7 October 16th, 2003 09:44 PM
