Disco 200Tdi Alternator P/N? - Defender Source
Old March 26th, 2009, 09:18 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
After driving home in a blizzard and depleting the battery down to 8v (no heater fan, no wipers!), I guess it's time to put a new alternator in. Good thing I was driving a diesel.
Anyway, I can't seem to find a consensus as to the part number. Are the disco and defender 200Tdi part numbers the same? I think it's STC233, but I've also seen STC234. Next question, anybody know of a supplier in the US that carries it?
Thanks!
Chance
Old January 29th, 2012, 06:37 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Thanks!
Any luck with this?
Semper Fi!
Old January 29th, 2012, 08:06 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I do believe a Range Rover alt from the same generation will work and is actually a very slight upgrade. I know this works on the defender motor.
Matt Browne
Old January 29th, 2012, 09:33 AM
Naplm00
Matthew
I've got a defender motor, but the last few posts I made might help.
http://www.defendersource.com/forum/...ad.php?t=29388
Old January 29th, 2012, 09:53 AM
Disco engines use the alternator with the adjuster on the right side. Defender engines use the one on the left.
STC233 is the 65 Amp unit.
You can probably also fit the 100 Amp unit from a 300TDI after you change the pulley AMR4248 or AMR5425 as long as there is space.
Old January 29th, 2012, 09:56 AM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Originally Posted by Wolf Fabrication
Any luck with this?
Nope, never did find out the correct part number. I ended up taking the old one to a local shop to be rebuilt.
Chance
Old January 29th, 2012, 10:59 AM
I clocked the disco alternator on my 200tdi in order to mount it in the defender/series orientation.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old January 29th, 2012, 05:35 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Same here
Old January 29th, 2012, 07:29 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
......and the early (mid eighties to mid nineties) Range rover alternator does work on both, which means you can get the thing anywhere.
Matt Browne
200tdi, alternator, disco, tdi
Disco and the 200tdi swap Stork17 Defender Technical Discussions 13 December 1st, 2008 08:30 PM
disco 200tdi temp sender D90user Defender Technical Discussions 2 February 1st, 2008 09:18 AM
D-90 1994 parts and Disco 2 parts JAD For Sale - Parts 10 August 1st, 2006 03:00 PM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
Help empty my garage! Ton's of parts.. RedRhinoProducts For Sale - Parts 12 June 1st, 2005 09:24 AM
