Disco 2 Master Cylinder / Servo on a Defender? - Defender Source
Old February 6th, 2016, 07:10 PM
UL1700
James
Defender 50th
With the LS conversion nearing completion, it has got me thinking about the brakes. I have a dead Discovery 2 sitting in the work shop so I was wondering if anyone has attempted to fit the much larger booster setup from the Disco into a Defender?
Any thoughts always appreciated
James
Old February 6th, 2016, 07:28 PM
Is the Disco 2 booster larger? Disco 2 brakes are horrible. I can't see how there is space in a Defender for a lager diameter. Disco 1s use a dual diaphragm booster that is a bit more powerful.
What brakes and calipers do you have?
Old February 6th, 2016, 07:30 PM
robertf
Robert F
1995 Discovery
not a good idea. disco firewalls are angled and defender firewalls are orthogonal. youll have to park at an incline to fill the reservoir
Old February 6th, 2016, 07:34 PM
Defenders use a 10" booster. Earlier ones use a smaller booster. If you have one of those switch to the newer version.
Brake Booster: LANDROVER STC4322 -compatibility, features, prices. Boodmo
Disco 1s use a dual with 8 and 9".
Brake Booster: LANDROVER STC1286 -compatibility, features, prices. Boodmo
Looks like Disco 2s use the same size.
Brake Booster: LANDROVER SJG000040 -compatibility, features, prices. Boodmo
Old February 6th, 2016, 07:36 PM
That is set by the brake box, not the booster.
Old February 6th, 2016, 07:38 PM
UL1700
James
Defender 50th
Cool, My defender is at the exhaust shop so I could not compare! The D2 booster is a monster double diaphragm type probably to try and get the horrid single pot sliding type front cylinders to stop the rolling mass of a D2!
Old February 6th, 2016, 07:43 PM
Okay. It should be bigger. Assuming the numbers are right 8+9 is 45% larger than a single 10. Not sure a double uses the whole area though.
Make sure you have the larger (46 mm) pistons on the front calipers for sure. Earlier 90s came with 41 mm.
Old February 6th, 2016, 07:47 PM
UL1700
James
Defender 50th
I think I may have a play, got nothing to loose really. Thankfully the 50th Anv Defenders came with the vented discs and large calipers anyway...
Old February 6th, 2016, 07:52 PM
Let us know how it goes.
A little Google says it might be too long. Not sure why as there looks to be enough space on my truck.
http://www.defendersource.com/forum/...rrc-19159.html
Old February 6th, 2016, 08:31 PM
UL1700
James
Defender 50th
Will do. I may pull the assembly out of the D2 later. Am guessing that there could be significant rhd / lhd differences.
Old March 14th, 2016, 02:38 AM
UL1700
James
Defender 50th
OK so I finally got to look at this and the results are that the defender MC bolts directly upto the disco servo and with a bit of filing the booster fits to the defender peddle box. On the rhd at leat space is not an issue. Unfortunately the actuator is about 10mm to short thus limiting pedal travel. I don't think that this is safe and I don't think the input shaft can be changed so it's probably game over. Oh well some one had to try it...
20160314_172327 by James Elphick, on Flickr
defender, disco, master
HOW TO: Dorman Clutch Master Cylinder Conversion (Defender & Series late-IIA & III) nathanwind Defender Technical Discussions 41 October 3rd, 2017 10:47 PM
Brake Servo and Master Cylinder Miller Wanted 3 April 6th, 2013 09:51 AM
Defender 90/110 Brake master cylinder brand new Shop On Broward For Sale - Parts 5 March 21st, 2013 05:22 PM
Clutch master - brake servo or fender wing removal ? JFD Defender Technical Discussions 14 November 20th, 2012 06:03 PM
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
