Disco 1 Low Beams Burning Out - Defender Source
Old January 16th, 2016, 09:37 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
My son's D1 has had two headlight low beams burn out in the past couple weeks. I'm thinking this might be a grounding issue. We're going to start by cleaning up the battery ground connection to the block. Any other suggestions?
Old January 16th, 2016, 09:49 PM
carlosz's Avatar
carlosz
Carlos
yes do check the grounds, the headlight socket used to burn on p38s and d1s due to improper contact, clean the contacts make sure they have the pressure tabs make good contact and trace the ground to the body, and clean..use dielectric grease to avoid further contamination.
btw the contacts are a pain to clean if not removed from socket.
Old January 16th, 2016, 09:50 PM
1of40's Avatar
1of40
1of40
Originally Posted by carlosz View Post
yes do check the grounds, the headlight socket used to burn on p38s and d1s due to improper contact, clean the contacts make sure they have the pressure tabs make good contact and trace the ground to the body, and clean..use dielectric grease to avoid further contamination. btw the contacts are a pain to clean if not removed from socket.
thanks C$
Old January 18th, 2016, 01:40 PM
1of40's Avatar
1of40
1of40
We sanded the surface points to clean metal on the ground wires we could find and replaced the Headlight bulb yesterday. We noticed the main ground wire was a copper bradded job that has turned light green. I was touching a fuel line as it rested in the chassis so I decided to cut a piece of old rad hose to sleeve it. Fingers crossed no new electrical gremlins.
Old January 18th, 2016, 01:43 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Dealing with the same situation myself... even replaced the pigtail and still having the same issue
Old January 18th, 2016, 01:48 PM
1of40's Avatar
1of40
1of40
What worries me is the grounds didn't really appear corroded. Did you get the connection behind the coolant tank? We need to go back now and paint over the connections before they do start to corrode.
Old January 18th, 2016, 02:03 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I hadn't touched the grounds, which one are you referring to? On the chassis or body?
Old January 18th, 2016, 02:25 PM
1of40's Avatar
1of40
1of40
Both. My understanding, which Carlos confirmed, is the D1's have historically had problems flair as a result of the ground wires corroding at the connection points. Probably worth a check.
Old January 18th, 2016, 02:29 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Good call... going to put a new "performance" harness in, will check then
Hi Beams out Bill Larson Defender Technical Discussions 8 February 15th, 2013 05:02 PM
low beams out D90user Defender Technical Discussions 2 March 20th, 2012 02:33 AM
High Beams cause Radio to short out... hillstrubl Defender Technical Discussions 4 April 22nd, 2010 01:37 PM
Headlights burning out.. rover4x4 Defender Technical Discussions 11 February 4th, 2008 11:03 AM
burning coolant mattdh Defender Technical Discussions 2 July 19th, 2005 05:29 PM
