dirty stepper??? - Defender Source
Old March 31st, 2004, 09:21 PM
ttegt's Avatar
ttegt
Thomas Tegtmeier
1995 Defender 90
Unhappy dirty stepper???
My '95 D-90 is trying to tell me something, I'm getting a code 48, which I believe tells me to look at the stepper motor, a solinoide??? maybe needs cleaning??? I think I found it, left side lower plenum chamber??? I removed this, how do you clean it??? I just put it back, reset check engine light, a few days later I'm getting a code 48... Am I on the right track? did I find the stepper motor? is it cleanable? do I just replace it?
The truck runs great, but that check engine light is on....
Old March 31st, 2004, 10:37 PM
neo812's Avatar
neo812
Kris
1985 Tithonus
Yes that is the Stepper Motor. WD-40 works well to clean them. It should have some movement of the shaft that extends into the plenum. Not sure if it will trigger the engine light. But I have seen erratic running and surging due to the thing being stuck. Maybe someone here can enlighten us both about the light. I personally wouldn't worry about it. My first Rover wouldn't even make it home from the dealer without it coming back on. A half dozen Rovers later and you quit worrying about the minor idiosyncrasies of the Rover
Stepper plunger worn oddly wicks Defender Technical Discussions 2 September 21st, 2005 09:25 PM
Code 48 Stepper motor devinchi Defender Technical Discussions 8 September 8th, 2005 05:43 PM
Installing a Napa Stepper Motor p# 2-1738 Heath Defender Technical Discussions 0 January 13th, 2005 10:04 AM
Stepper motor same on RR? waveridin1959 Defender Technical Discussions 15 December 16th, 2004 10:52 AM
stepper motor erik d Defender Technical Discussions 2 February 11th, 2004 04:09 AM
