dirty coolant - Defender Source
Old October 16th, 2006, 02:38 PM
Hollywood
alex howell
94 d90
dirty coolant
Started my truck today, and smoke was coming from the rear right side of the engine, and from the right air scoop. It was a dirty white color, smelled dirty, but I could not guess what it smelled like. I could not pin point the location.
I checked all my fluids, which were at normal levels. My colant has black and white liquid specs floating on the top. Truck has been parked for 3 weeks, over cardboard, no dripping.
My tuck has 70,000 miles, only 6,000 in the 3 yrs Ive owned it. I have it serviced regularly.
Any ideas what is goining on. I have LIMITED mechanical knowledge and was thinking oil cooler lines, engine rebuild (head gaskets were done at 56,000), or both.
Any advice would be appreciated.
Old October 16th, 2006, 03:30 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
If you can get it to start smoking again, I could concievably help you at least pin point where it is comming from. Let me know if you`d want some help
Old October 16th, 2006, 04:10 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Check your oil dipstick. See if you have a foggy/milky color to your oil. Let us know.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 16th, 2006, 04:47 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Check your coolant for exhaust gasses. NAPA sells a block checker to do this, about $50.
Old October 16th, 2006, 08:16 PM
Hollywood
alex howell
94 d90
I can get it started without a problem, it takes under a minute for the smoke to happen. My oil is normal, brown. I will swing by napa this week. I am going to see if a freind who is mechanically inclined (with rovers non the less) can swing by next week to help solve the mystery.
Thanks for the quick responses
coolant
Engine Coolant what kinda rover4x4 Defender Technical Discussions 12 May 17th, 2009 11:02 PM
coolant - which to use scoloco Defender Technical Discussions 37 May 2nd, 2009 04:24 AM
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
