Dipstick problem - Defender Source
Old July 18th, 2005, 09:37 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
Unhappy Dipstick problem
Well, I got the head gasket job done on the 90 finally. Managed to find where everything seemed to fit and all. It even started on the first try. Woohoo! It spit smoke, the rockers clattered like crazy, and it thumped a bit at first but it started.
The only problem I have now is I can't get the oil dipstick back in. I goes about 1/4-1/3 of the way in then stops and will go no further. We did not remove the tube when replacing the head gaskets but it did get rotated down out of the way when it got bumped. We rotated it back up to where it was and now we're stuck. It's not a show stopper right now but I'm fairly sure in the future I'm gonna want to check my oil level.
Any ideas?
A Land Rover would never turn up to collect an Oscar, it'd be far too busy doing something important somewhere for someone - Top Gear
Old July 18th, 2005, 11:23 PM
mattdh's Avatar
mattdh
Matt Hurst
you can pull the dip stick holder out to see if that got bent or if something is clogging it
Old July 18th, 2005, 11:29 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I did the same exact thing, not to worry, you just need to rotate the tube back into place. Just wait until you fire up the engine, the aluminum block expands at a faster rate than the steel tube, so when that happens it will move a lot easier for you.
-Hans
My oil line fix
My 100k stopped odometer fix
Help! Problem starting (95 SW) reaper99999 Defender Technical Discussions 8 March 2nd, 2006 07:22 PM
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
D90 Ground Problem? cdnpaul Defender Technical Discussions 0 December 4th, 2003 03:36 PM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
