Dim light - Defender Source
Old January 23rd, 2010, 08:09 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Dim light
I've got a dim headlight. I assume that it is ground related with my prior experience involving being shitty at wiring. First thing that comes to mind is that the plug may be the problem. I wanted to ask you experts what the common problem is. Thank you in advance.
And hay
And I love you too
Old January 23rd, 2010, 10:09 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Could just be an old bulb. Sometimes instead of failing, they just get dim really fast, particularly non-haolgens. Got another bulb to try?
Either that, or check the voltage at the connector to see if you've got a drop in voltage there. If that's the case, first thing I would check is the switch. It's a known failure point.
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 24th, 2010, 08:42 AM
huck1974's Avatar
huck1974
shane cates
94 d90
And hay
And I love you too
Old January 25th, 2010, 02:50 PM
outfield
Steve
1995 D-90 SW #351
Check the terminals in the plug where the bulb plugs in. I had the same issue and there was some corrosion on the termianls. Pulling the bulb and reinstalling it was the quick fix. Cleaning the terminals took care of it for good.
Old January 25th, 2010, 03:03 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
+1
Dim usually mean bad ground connection. Clean everything up and try it again before you buy any parts.
Email:
Old January 25th, 2010, 03:05 PM
Also check as I have seen the plugs melt -- the three prong one that goes in the back of the headlight.
Old January 25th, 2010, 07:27 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I also use dielectric grease even on interior lights when I change them--it keeps corrosion from being a nuisance.
ht
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
Intreior Light Problem proulx70 Defender Technical Discussions 3 February 7th, 2007 05:30 PM
H4 retrofit lens/bulb combo = dim lights! jaherring Defender Technical Discussions 1 January 18th, 2005 12:37 PM
Rear Dome Light Stays On thug1313 Defender Technical Discussions 5 November 1st, 2004 08:33 AM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
