Dim Instrument Panel Lights - Defender Source
Old June 20th, 2004, 03:49 PM
gearco
James T. Johnston, Jr.
1986 D110
my instrument panel lights are so dim i can barely read them at night. is there an adjustment knob somewhere,or should i buy a flashlight?
Old June 20th, 2004, 04:04 PM
Check the dimmer switch on the dash under the headlamp switch. They can come disconnected real easy.
Old June 20th, 2004, 11:29 PM
gearco
1986 D110
thanks.
ht, lights
All lights seem dim johnpiero Defender Technical Discussions 5 December 12th, 2008 01:12 PM
H4 retrofit lens/bulb combo = dim lights! jaherring Defender Technical Discussions 1 January 18th, 2005 12:37 PM
Moving Dim Lights.... Eric Siepmann Defender Technical Discussions 3 November 22nd, 2004 11:46 AM
Instrument Panel wiring loykd Defender Technical Discussions 6 October 18th, 2004 10:16 AM
dash gauge lights very dim Marc Weinstein Defender Technical Discussions 15 October 17th, 2004 01:49 PM
