Dim headlight (REALLY dim) - Defender Source
Old July 24th, 2013, 01:36 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Now that I've installed a new right headlight socket, I've not solved my problem.
The headlight is very dim on low beam and nothing at all on high beam. I've swapped the bulbs left/right with the same dim right light. All the fuses are good.
I'm not talented at chasing wiring problems so where do I start?
Old July 24th, 2013, 01:43 PM
If you haven't done so already install a relay on the circuits. The factory makes all the watts run through the switchgear which does help brightness.
Old July 24th, 2013, 01:47 PM
Mike,
Is your truck here in PHX? If so, bring it by the house. I'm 100% sure it is a wiring issue. If not, call me anyways.
Old July 24th, 2013, 02:04 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Never mind. AGAIN my wife fixed it.
"Well, the wires come out and go to those connectors. Let me pull and replug."
Now it works. I'll save the story of her fixing the starter for later.
Mike.
Old July 24th, 2013, 02:05 PM
Don't start there .... that's just adding more complexity to your problem.
Start with simple common issues ... like the light switch itself ... these are a known weak point.
Once you've fixed this issue then consider the relay which can help improve brightness. Its all relative though in a rover.
Rovers North Front Headlight Guards $180 Wolf Fabrication For Sale - Parts 2 November 2nd, 2011 08:41 PM
Headlight Switch Issue, any ideas? januconn92 Defender Technical Discussions 1 July 24th, 2005 11:53 AM
Mesh Headlight Guard NashvilleRedD90 Defender Technical Discussions 5 April 18th, 2005 03:20 PM
Moving Dim Lights.... Eric Siepmann Defender Technical Discussions 3 November 22nd, 2004 11:46 AM
headlight switch sub jorge Defender Technical Discussions 1 January 24th, 2004 09:10 PM
