Dilling holes in aluminum body panels - Defender Source
Old March 22nd, 2008, 11:32 AM
fenwaystan's Avatar
fenwaystan
Christopher Giles
1997 D-90
All--
Quick question: I am going to mount my Troy Storage Boxes and Rover's North wingtop/bonnet protectors soon. This will require me to drill holes into the body panels and rear fender wells for the various fasteners. After I have drilled my holes, is there any particular prep steps I should take to protect the exposed metal before fastening things together.
Thanks in advance.
Christopher
Old March 22nd, 2008, 01:14 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I would use mylar washers on the bolts next to the aluminum body--other than that, I did not. This is to protect from galvanic reaction. If you use steel bolts, the bolts usually rust--if you use stainless bolts, the body usually oxidizes. I suppose treating the exposed aluminum with some sort of paint is not a bad idea, but aluminum being as soft as it is, you can't expect it really do much (it will scratch off too easily).
aluminum, body, panels
Holes in body kennybahr Defender Technical Discussions 23 January 22nd, 2008 07:23 PM
Black Friday Special - Stainless steel door panels LenB For Sale - Parts 18 December 23rd, 2006 11:56 AM
d-90 body panels needed ember Wanted 0 June 28th, 2005 01:57 AM
Body Panels and Work- Atlanta gtg067i Defender Technical Discussions 1 February 14th, 2005 05:03 PM
body work on aluminum mattdh Defender Technical Discussions 11 July 4th, 2004 02:47 PM
